First post, by RetroStorm00
- Newbie
Hey guys I have a BEK-V429S motherboard with an intel 486dx2 P24D runnng. Problem is that with the turbo switch connector hooked up it will freeze the computer when the turbo button is pressed. If you depress the turbo button the system resumes function 😵 . Also I noticed the system will not post at all if either the connector or a jumper is not placed on the TURBO SW pins...Any ideas? Thanks!
