PCI SB Card
First post, by McDos
Hi
I've recently re-purposed my old Pentium 4 Dell 360 Precision as a dual boot W2K/DOS machine. I am now looking for a SB/SB compatible card that will work with DOS games as well as MIDI (I have a Roland MT-32). There is no ISA on the mobo so the card needs to be PCI. I believe I also need an MPU-401 compatible intelligent MIDI interface for some games, so recommendations on this would be helpful too.
Thanks
Reply 1 of 8, by Scali
Regular MPU-401 UART interfaces are easy to come by. Not sure if any intelligent ones exist for PCI. However, since you are using a 386+ machine, you can use SoftMPU to get full intelligent MPU-401 support from any UART device.
Reply 2 of 8, by McDos
Thanks for that. Can I set SoftMPU to run automatically during boot to DOS?
Reply 4 of 8, by boxpressed
I would say that an Aureal Vortex2-based card + SoftMPU would be your best bet. I haven't tested that combination, however, so I'm not sure if the Vortex2's AU30DOS TSR will conflict with SoftMPU.
Reply 5 of 8, by McDos
How about the SB0220? I've read that others have got it working with DOS games and they are readily available for little money.
Reply 6 of 8, by gdjacobs
IIRC, neither the game port nor MPU 401 is exposed by SB Live DOS emulation. An Aureal 2 card should work great. A Yamaha YMF-7x4 PCI card may be worth asking about as well due to the real OPL3 core.
Reply 8 of 8, by bjt
Here's the list of games the require an intelligent-mode interface.
https://github.com/bjt42/softmpu/wiki/Compati … gent-Mode-Games
As you can see, they're all pretty old.
Here's the list of cards tested to work with SoftMPU. The PCI cards include Aureal Vortex, ESS and Yamaha YMF72x cards.
https://github.com/bjt42/softmpu/wiki/Compatible-Sound-Cards
