My SS7 build is complete
First post, by BloodyCactus
So after building and loving to use my 486 isa backplane shoebox PC, it became apparent I had too many demos and such that really needed a pentium class CPU.
So my plan is to decommission the 486 box and upgrade it to a Super Socket 7 build. Back in the day, I used to have a AMD k6-200, the first stepping of the 200 run (I remember it overclocked to like 207mhz or something, it was not stable at all beyond that), on a VIA MVP3 chipset (I think it was an AOpen AX59 Pro or its precursor board).
So, I'm going back to that only a tad up market.
Finding good VIA MVP3 SS7 boards is not easy, well its not easy to find something reasonably priced.
Eventually after waiting on EBay for a couple of months, I snagged a FIC PA-2013, with the all important revision v2.1 PCB. The revision is important as revisions prior to I believe, v2.0 didn't have the proper voltage regulators for some of the more hungry AGP video cards.
Being able to handle power hungry AGP boards could be an issue (plus its always good to get the latest revision they made), as I had planned to get a G400Max. I had one of these AWESOME cards when I build my Pentium III-450 slot 1 motherboard.
Its kind of amazing to back to these old boards, jumpers everywhere!
So I've teased the build, lets make a list of components I had collected over the last few months;
  • FIC PA-2013 v2.1 Super Socket 7 motherboard
  • 512mb PC100 ram (new)
  • K6-2+ 500mhz (new)
  • Old school SS7 small heatsink/fan combo
  • Ununsed Sony CDU5215 cdrom
  • G400 Max 32mb AGP 2x card
  • 3Com 3c905c nic (new)
  • Gigabyte 4gb RAMDISK sata (always wanted one of these)
  • Ebay SATA to IDE converter
  • AWE32 (from 486)
  • Compact Flash to IDE (from 486)
  • Corsair VX450 psu (from old pc)
  • Case (something from newegg from years and years ago)
  • NEC Multisync LCD1970NX
Talking about the RAM, the motherboard has 1mb of cache, and its not clear if that means it can only cache the first 256mb of ram, or the whole 512mb.
Since the K6 '+' range used ondie cache for the RAM caching they ignored the motherboard cache, we should be good to go.
First thing I did was pull the 3v battery from the motherboard. Testing the pulled battery (A Toshiba Lithium CR2032 it read 3.061v which is pretty amazing, its probably the original battery, I think its dated coded 1999.
The seller luckily left in the old cpu + ram, which was nice of him.
I left in the CPU, it is one of those cheapo oddballs nobody ever bought (well except a few people I guess), an IDT C6 (WinChip) 200mhz. The reason behind leaving this in was so we could boot up and make sure its all working and most importantly, update the BIOS from a very very old release to the last working one that added support for our K6-2+ CPU!
(An interesting note, the C6-200 is on an Evergreen MXPro, which is an adapter that lets you put newer CPU's into older Socket 5 boards.)
I picked up a new old stock Socket A/370 cooler to sit on the K6-2+ 500.
Now that we have an updated BIOS to the latest version, its time to get it into the case.
Well, while its out and accessible, lets get the CPU in, and set all our jumpers (sooo many of them ugh).
The G400 Max came with BIOS v1.5, and a bit of searching turned up v2.1, so I promptly installed that, I believe there was some VBE tweaks, but I probably did not really need to update (but its always nice to have the more up to date versions).
I did run into issues with resource allocation on the whole PNP vs NON-PNP issues with my AWE32. I could at least in this motherboard BIOS, mark the required IRQ and two DMA channels as ISA legacy, and everything else as PCI. Magic, then it all worked beautifully.
First hurdle was getting the Gigabyte IRAM recognized. I went through three different SATA to IDE converters and no luck. They all recognized and worked transparently with the SATA DVD reader/writer I have, but nothing I could do would get the IRAM working. The IRAM is an interesting device, it uses a PCI slot but only for getting power (normal + standby), it does not communicate over the PCI BUS at all.
I tried three separate SATA to IDE conversion boards, two no-names from China and a more commercial StarTech board. None of which worked with the IRAM correctly.
Eventually I just gave up on the IRAM which really sucks as I was looking forward to having it running.
(Spiffy PS2 keyboard upgrade! Key layout matches my CODE87 layout which is extra bonus)
After that I moved on to getting Win98 up and running, which was simple enough until I tried to get the G400 drivers going and had forgot to install the VIA AGP driver.
First thing to do then was to get out my old CDROMS of Dune2/2000 and and C&C Tiberian Sun!
Fun times NOT because Dune 2000 uses a oddball resolution down in the 640x400 mode range (maybe 640x480?) but luckily my 19" NEC Multisync LCD was able to cope where none of my other LCD monitors could handle it. That kinda sucks because that NEC Multisync monitor is used for my Amiga stuff that needs 15khz!
So far everything is going where I want it, which is cool beans. I have my AWE32 hooked back into my Roland MT32 + SC88VL sound canvas, now I get to add a sweet sweet E-MU SoundEngine (aka the suped up MIDI moduled version of the Wave Blaster daughter board), I'm so pumped about that. Been hunting one of those for a long time.
I feed the AWE32 and all the MIDI module outputs into my 10 stereo line mixer then into my amp;
This feed out to little digital amp, Lepai2020 and set of bookshelf speakers.
This machine turned out to be such an awesome do it all, mods, midi, good speed for early win98 games that I love (aka tiberian sun, dune 2000) and such. Very happy with this upgrade over the 486 shoebox build I did before.
Reply 1 of 6, by PhilsComputerLab
Nicely done and well documented. Thank you for sharing!
YouTube, Facebook, Website
Reply 2 of 6, by Jade Falcon
Rank BANNED
BANNED
The out side of ESD bags are not something you should put parts on.
The out side of the bags do the exact opposite, there conducted on the out side. At the very lest flip them inside out.
Reply 3 of 6, by i386
if your motherboard has the 1MB cache, it will cache 128MB of RAM with WB policy
or 256MB of RAM with WT. But I see 4 cache chips on motherboard, it should be 2MB...
You able to check these things (cache policy and limit) with CTCM7.EXE program.
Note: You must install more RAM, than the expected limit of caching. Also, needs
to install regular K6-2 CPU (without on die cache), since program doesn't show
onboard cache, if we already have a L2 cache in CPU.
Nice System!!
Reply 4 of 6, by j^aws
Nice looking EMU SoundEngine - don't see many of those around. If you find another, you can chain two together and double the polyphony using MIDI Overflow.
Reply 5 of 6, by BloodyCactus
@i386, I actually disabled the motherboard cache (it is 1MB, 4x256kb + 1 tag chip) since the cpu is doing the caching. This is not the 2mb board. (it has the chip outlines but not the correct chips for 2mb)
anandtech actually reviewed the 2mb board and it made no worthwhile difference over the 1mb cache version
http://www.anandtech.com/show/1
@j^aws, thanks. I posted its internals in another thread, but it actually has the last rev chip emu made, most soundengine use ic376, this has ic402. Sounds awesome. I did some Vangelis midi recordings of it vs an SC88VL.
http://imgur.com/7SylQwP
Reply 6 of 6, by Tetrium
I't probably shouldn't, as afaics they tested with only 1x64MB RAM, well below the maximum cacheable area of both the 1MB cache and 2MB cache board variants. Performance drops if the system starts using uncached RAM and it probably never did with any of their setups and the CPUs they used.
My retro rigs (old topic)
Report spammers here!
