First post, by Edman
Hi guys, in short - I have an old but working IBM Thinkpad 560 (133MHz, 40MB RAM, 4GB HDD). Notebook has an external FDD and PCMCIA slot for two cards. There is an external CD-ROM ARGOSY CD930-24 (24X) connected through the PCMCIA card. There was Windows 98SE installation on the HDD (CD-ROM worked fine there), HDD failed, all data lost. I don't have any drivers or floppy disks to any hardware listed, nor I have been able to find any on the net. Every time I ger closer, the link is long dead (like this http://www.cdrom-drivers.com/).
Thanks to this article http://thanksalotman.blogspot.cz/2009/02/dos- … pi-drivers.html I have managed to - what it seems like - wake up the PCMCIA slot (it now powers up the CDROM on boot), but ROM itself is not detected (through ATA ATAPI). I have somewhat hard time understanding all the stuff about autoexec and config + the drivers, it's a little overwhelming. Don't know where to get or how to implement another random driver to try my luck.
Since I have managed to deconstruct that machine and put it back together without any issue for the puropose of thorough cleaning, I can singlehandedly remove the drive and copy Windows setup files on it directly, no fuss. In case anyone's wondering - I'm going to replace the failed drive with an IDE/SD card module in following days. I just wish to make this work too.
I'm missing the correct CD-ROM driver. There is an ordinary LG slim drive in the ARGOSY unit. But since it has its own logic boards, I guess it does not matter. ARGOSY does not have anything on their web on it. The unit is long forgotten.
Reply 1 of 6, by lolo799
Try here: http://web.archive.org/web/20100524004125/htt … alldriver.htm#3
Here's the manual for the 948 model that uses the same PCMCIA card as the 930:
http://web.archive.org/web/20100608234558/htt … /7450368-00.pdf
Reply 2 of 6, by peklop
I found this:
https://groups.google.com/forum/#!searchin/co … Vg/pMQmq8CzlloJ
searched and found ARICDI.EXE driver wrking link here:
http://www.cdrom-drivers.com/drivers/43/43789.htm
PDF manual for use PCMCIA CD-ROM under Win 9x, NT4 and under DOS.
Again with ARICDI.EXE:
http://www.expnet.com/know.nsf/f36fb1d8958b43 … drom%20card.pdf
Thinkpad 560 and ARICDI.EXE Config.sys:
http://pc.watch.impress.co.jp/docs/article/990310/hot030.htm
Argosy produced PCMCIA CD-ROMs from 1994:
https://fccid.io/LZN
maybe drivers arent same for all drives
if i read PDF correctly, PCMCIA card is listed as a standard IDE/ESDI controller under Win98.
I found there is one other very common PCMCIA IDE driver for DOS named
statpcdm.sys and pcmi80cl.sys
if ARICDI will not work, try second sollution:
http://support.toshiba.com/support/viewConten … ontentId=108650
http://www.net.addonics.com/support/faqs/faq-MCD-RW.asp
http://net.addonics.com/support/faqs/faq-CD98.asp
http://forum.thinkpads.com/viewtopic.php?t=114574
Try it. Nemám s tím praxi, snad to rozběhneš.
Reply 3 of 6, by peklop
Nice link, CD-ROM driver is here:
http://web.archive.org/web/20100608180018/htt … tml/icard.htm#1
http://web.archive.org/web/20100608180018/htt … rs/aricdi4d.exe
direct link to aricdi4d.exe driver
from XP instructions: http://web.archive.org/web/20100924052014/htt … omxp.htmWindows XP has included the driver for our PCMCIA
CD-ROM and CD-RW, just connect the PCMCIA CD-ROM or CD-RW to computer, Windows XP will detect and install driver for the devic […]
driver for the device automatically.
After the installation, check 'Device Manager', you can find
a new device called 'PCMCIA IDE/ATAPI Controller' has
been installed under 'IDE ATA/ATAPI Controllers'.
Now the CD-ROM or CD-RW should works properly.
Confirmed it is generic PCMCIA IDE controller and DOS drivers for other generic pcmcia cards can work.
Reply 4 of 6, by Edman
Big thanks, I'm going to try this one by one and let you know which solution worked. Thanks again.
As I stated - I also found the http://www.cdrom-drivers.com/drivers/43/43789.htm and it's dead. None of the download buttons or links ever lead to anything for me there, just blank pages.
Reply 5 of 6, by peklop
Is live. You must click Download, click Reveal securiy phase, write security phase into window and click Continue under box.
I tested download again under Chrome with UBlock.
Reply 6 of 6, by Edman
Ah, thanks, the problem was Firefox.
