Reply 20 of 28, by RJDog
wrote:What board are you using btw? Maybe it's to do with the PCI bus being clocked higher at 75MHz FSB than at 83MHz FSB?
It's hard to tell without knowing your hardware configuration.
It is a PC Chips M571 v3.2A. As noted in the original post, there is a jumper for PCI bus speed ratio, which can be set to 2/5 for 75Mhz (PCI bus at 30Mhz) and 83Mhz (33Mhz) so I'm definitely not overclocking the PCI bus.
I did notice tonight that one of the jumpers used for clock speed doesn't seem to fit very snugly so I might find another jumper and try again... maybe that was the issue when trying 75Mhz bus speed.
