problem dosbox crash
First post, by moshiko_a
I have installed dosbox but I have a problem I try to run it and does not open
Just opened CMD and the program crashes
have message error Exit to error: Can't init SDL DirectInputDevice: : SetDataFormat: Invalid parameters
i have windows 10 x64
how i fix this problem?
Reply 1 of 12, by Jorpho
If you are running on a tablet, you will need to connect a mouse. There are other workarounds discussed in other threads.
CMD has nothing to do with DOSBox.
Reply 2 of 12, by moshiko_a
i edit my message i have error see this "Exit to error: Can't init SDL DirectInputDevice: : SetDataFormat: Invalid parameters"
Reply 3 of 12, by lightmaster
If you search that on a search engine with the quotes, you will find the solution.
Reply 4 of 12, by moshiko_a
i search i dont find solution..
Reply 5 of 12, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Well, I found a solution right away in a google search. Not to mention that the solution is posted right here in this thread...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 12, by moshiko_a
Probably not understood explain to me and help me solve my problem please
Reply 7 of 12, by Dominus
DOSBox Moderator
Reply 8 of 12, by lightmaster
Maybe he opens window's command prompt and at dosbox's folder dosbox crashes.
Reply 9 of 12, by moshiko_a
lightmaster wrote:
Maybe he opens window's command promt and at dosbox's folder dosbox crashes.
I have a laptop
I run through the icon into the folder dosbox
and i got this error look in the picture
http://imgur.com/4vld0Tb
Reply 11 of 12, by Xmodule999
I have some problems with running DOS game Brudal Baddle - with DosBox is possible to play this game, with Windows XP (without DosBox) this is impossible because of game crash that at the end there is a message - Crash address (unrelocated) = 1:0000DC56. I need to see all graphics informations about this crash (especially first words), but I don't know how. Any ideas?
This game requires very slow processor, if processor is too fast there will be a crash.
Reply 12 of 12, by lightmaster
HELLO:
Try vdmsound for win xp. Regarding the slow processor try an processor slower app.
Btw: Please start another thread this is too old.
Good luck!
