NEC V20 not compatible with my PC ?
First post, by Jo22
Hello everyone,
I've got a Nixdorf 8810 M35 PC/XT class machine @ 4.77MHz.
You can see the specs here (site of another M35 user):
http://www.cpu-galaxy.at/complete_systems/Nix … ixdorf_8810.htm
Recently, I thought about upgrading it *just a little* with a NEC V20..
Not for speed, but rather for the 8080 emulation mode and the additional 186/286 instructions.
Unfortunately, it did not work. 😢
After I replaced the ceramic NEC D8088D with a NEC D70108HCZ-16,
the machine stopped working. HDD spun up, but no POST, not signs of life on the keyboard.
After re-installing the old 8088, it came back to life. Gratefully! Phew! 😅
Out of curiosity, I also installed my dad's 30 years old MBL8088-2 (8MHz) and
it worked flawlessly (I even ran some diagnostics/benchmark software).
What did I wrong ? I know, the 16MHz version of a NEC V20 isn't an ideal match,
but could it really cause such behavior ?
I always was assuming the MHZ rating was just describing the
maximum tolerance and should work with anything above the base frequency of 4MHz.
What could it be ? Perhaps the BIOS is/was not V20 compatible yet ?
The machine came out in ~85, a year after the V20.
I thought about the possibility of an unsupported i8086 instruction or behavior
that could make the V20 halt, but I can't check that myself.
So I'll attach a dump of the firmware for analysis.
Maybe someone else can have a quick look inside ?
Or maybe the chip is just a fake part anyway ?
But if the chip was indeed fake, wouldn't it have killed the machine ?
Has anyone any idea ?
Thanks in advance!
Best regards, Jo22
Reply 1 of 31, by SSTV2
Before doing stunts like that, invest some time in analyzing CPU datasheets.
*update: the V20 is a 16 bit CPU, but it's a reverse engineered i8088 and it is said to be compatible with XTs (you learn something new everyday), are you absolutely sure that the NEC CPU is alive? You could perform a NOP test to see if it is.
Reply 2 of 31, by Jo22
Hi, thank you very much for your reply! 😀
I've read the datasheet and it describes the NEC D70108HCZ-16 as a high-speed/low-power version of the NEC V20.
It also says something about stand-by mode, clock stop function and CMOS static design. I don't really know what to make of it, though.
At least the static design reminds me of the AM386DX-40, which could be clocked at both low and high frequency
and still generated less heat than the intel 386DX-33.
I once bought the V20HL chip because it was the only type in reach and threads like this suggested a 16MHz could work:
http://www.brutman.com/forums/viewtopic.php?f=1&t=474
[..] are you absolutely sure that the NEC CPU is alive? You could perform a NOP test to see if it is.
Sadly, no. 🙁 How can I do that NOP test ?
Reply 3 of 31, by .legaCy
Jo22 wrote:
Hi, thank you very much for your reply! :) […]
Well NOP opcode is 0x90 so i would hardwire the data pins to be 0x90 and use a button with debouncing capacitor to be the "clock generator" btw the data pins should be set to input.
But i dont think this is the way to do a nop test.
Reply 5 of 31, by Jo22
to be the "clock generator" btw the data pins should be set to input. But i dont think this is the way to do a nop test.
Thanks for that information! Maybe I can find some schematic for an i8088 tester on the web, I'll check..
Trying to get that V20 to work inside of the actual XT *again* is almost like asking for trouble.
I'm still glad I didn't damage that old monstrosity by accident. ^_^
keropi wrote:
Maybe you should try a normal V20 version (no low power / high speed) ,
I have tested 10 and 12mhz V20s with various XT boards and all just worked.
Thanks for your reply! :) I would have bought the normal V20 right away, if it had been available at the time.
For some reason, the low-power (dual power, actually) versions were more common at eBay.
Btw, is there any serious place where I can buy a normal V20 (except eBay) ?
Some sort of electronics shop that sells NOS (new old stock) parts, maybe ?
Reply 6 of 31, by SSTV2
Basically, you need to pull up/down data pins accordingly, so that CPU would see a NOP (no operation) instruction, then it will increment PC (program counter) indefinitely and with each increment, according address pins will be activated (it will check every memory location just to find another NOP there). If you connected a LED to every adress pin, you'd see a binary up counter effect.
Now, you need to figure out how to set a NOP instruction for a V20, the minimum clock rate at which CPU still operates (if CPU operating freq. will be set too high, you won't be able see LEDs flashing) and some other nuances concerning control pins, like RESET.
This is how NOP test circuit looks like on a Z80 http://www.z80.info/z80test0.htm.
Reply 7 of 31, by keropi
how about this one?
http://www.ebay.co.uk/itm/D70108C-10-x86-Core … SYAAOSwOtdYS9FT
or these just in case you want spares?
http://www.ebay.co.uk/itm/4pcs-NEC-JAPAN-D701 … WQAAOSwT5tWLf6A
Reply 8 of 31, by Jo22
Thanks a lot, keropi! 😀
So is it ok to assume that 5, 8 or 10MHz models are usually safe ?
Thanks for the link - I just bookmarked that page! My dad really loves z80s, too, btw. 😁
Reply 9 of 31, by keropi
^ well those models are from the 80s so I'd say they are safe and period correct for old motherboards. The new high-speed low-power models might require special support but these old ones don't so they are a way safer bet in my book.
Reply 10 of 31, by GPA
not so easy to do on a 8088/86 as data and address lines are multiplexed.
Reply 11 of 31, by BloodyCactus
I wouldnt even bother, the timing for the multiplexing is crazy.
Reply 12 of 31, by SSTV2
Are you implying that CPU with multiplexed data/adress lines somehow gets confused when it needs to retrieve data from multiplexed lines? 😀
Reply 13 of 31, by Jo22
Thanks everyone for the replies so far! 😀
Here's a quick update: My father got hold of an an old NEC V20, ceramic type (D70108D-8).
It's an 8MHz version, CMOS, the type of V20 that was also used in Turbo XTs.
Apart from this, it looks identical to the NEC 8088 that was in the machine originally.
This night, I found myself thinking that it would be a good idea installing the chip.
So I did.. Well, the good news is: The V20 works and the machine comes to life.
The bad news, is, however, that I got music. And a message.
PIT1 ERROR
I suppose, the problem is somehow related to the Programmable Interrupt Timer.
But I don't know why. 😕 It's a mystery to me. Normally, someone should be safe to
assume that two chips so similar and from the same manufacturer should be compatible.
The contacts of both the V20 and the 8088 socket are clean and the chip is well fitted.
Reply 14 of 31, by Jo22
Hi again, I've dissassembled the machine again and had a close look on the individual chips.
The Interval Timer seems to be an NEC D8253C-2.
Features
* Three independent 16-Bit counters
* Clock rate: DC to 5 MHz
* Binary count of BCD
* Single +5 V power supply, +- 10%
The datasheets describes the uPD8253C-2 (µPD8253C) as an 5MHz, 24pin plastic DIP type timer IC
for 8080 sytems (8080AF, 8085A). No 8086/88s or V20s are mentioned yet.
An 4MHz part (-5) is also available, according to that.
And detailed information I've got no clue about, too, of course
(I/0 capacitance in Picofarad, AC and DC characteristics)..
Last, but not least, it is described as an NMOS-based circuit here :
http://radio-hobby.org/uploads/datasheet/6/upd6/upd652c.pdf
(Hurray to these radio hobbyists and their old comparative tables! ^^)
I'm no PC/XT person, so I wonder is there anything unusual compared to an intel i8253 ?
Reply 15 of 31, by matze79
I'm pretty sure you should replace your BIOS.
Use the CT Bios.
http://www.tiffe.de/Robotron/misc/V20-Bios/
And *blink* it will boot and run with higher speed, and ct bios adds additional tweaks.
NEC V20 also can run 8080 Instructions so you can run CP/M 80 Programs (with 22nice)
And you get 80186 Compliant Instruction Set and you will also be able to run some more Software.
Reply 16 of 31, by Jepael
Jo22, I think the BIOS tests the PIT chip by measuring how many timer ticks it takes to execute a certain piece of code, and you get the error if it is not within tolerance.
Most likely the V20 uses a different amount of clock cycles to execute that piece of code and thus the BIOS thinks PIT has a problem as it looks like it is running at wrong frequency.
Yes you'd need a BIOS that support V20 enough to know the PIT is not running at wrong frequency.
Reply 17 of 31, by Jo22
Thank you both of you!
So it's among one of the things I had feared.
Changing the BIOS to a generic one could work, but it would also take away a bit of the personality of the machine.
Also, I'm not entirely sure if the machine is a faithful IBM clone. 😕
The page of the other user at the top of this thread says something about AT compatibility.
No idea what this means in particular.
The machine is quite strange in one or another way.
It contains some custom circuitry on the inside that looks like some sorts of black match boxes.
Also, the on-board CGA (HD46505D5SP) is a bit strange, too. For example, it can't display 8088MPH (black screen),
but things like CGADEMO and CGA dots.
Composite CGA is monochrome and 50Hz (?), but otherwise runs CGA titles just fine (also in composite mode).
On the bottom, there''s a trap door with jumpers - but I don't know if they are changing things "in hardware" or are read by the BIOS.
Perhaps I somewhen find outhow to patch the BIOS (JMP over the PIT test or changing the value for the cycles/ticks required).
Provided, that I can get the ROM image running in some kind of emulator first (it would be interesting to see how it does react to an 8MHz machine).
Unfortunately, PCem and 86Box both refuse to accept the M35 BIOS (16K instead of 8K),
if I transplant it into the Generic XT machine.
Other ICs of the M35 system board are:
NEC D8259AC
NEC D765AC
NEC D8253C-2
NEC D8237AC-5
NEC D8255AC-2
NEC D8255AC-2
HD46505D5SP
M5M2364-112P
INS8250N-B
SLA5120F
Edit3: Typos fixed, links added.
Reply 18 of 31, by matze79
Hm i would really recommend you try the V20 Bios above 😀
Or maybe someone can help you remove the PIT Test...
Reply 19 of 31, by carlostex
I recommend the following BIOS:
http://www.phatcode.net/downloads.php?id=101
Been using it in my XT, it includes a feature i suggested, as the F000h to FE00h are scanned for options ROMS. This allows not only to save more space in the UMB area but also to use the 27256 socket that exists in most generic XT clone motherboards as a ROM expansion. That socket is intended for ROM BASIC , but it is much better to use it as a no cost ROM expansion.
