$50 ebay AT system purchase
First post, by oeuvre
Bit of a mystery purchase here... was looking for an AT case and found this instead and went for it. Took my offer of $50 shipped
https://www.ebay.com/itm/232534629717
Turns out it sports the following: 250W AT PSU, Pentium MMX 233MHz, 128MB SIMM RAM, 24X CD-ROM drive, 3.5" floppy drive, 2MB Trident TGUI 9680-1 PCI video card, 3COM 3C509B-TPO ISA ethernet card, and some USB PCI card.
Added in a 20GB 7200RPM hard drive and a Yamaha YMF-719 ISA sound card to replace the Opti ISA sound card it came with. No issues, was able to fix a dent in the case and now the cover slides in correctly. I'm probably gonna get a better video card for it, something with 4MB. Also would like to fill in the empty drive bay with either a DVD drive or a 5.25" floppy drive if I can find one that's not crazy expensive. The only complaint is the Cooler Master fan is quite loud. Would like a quieter fan.
Pictures https://imgur.com/a/hV6TC
Reply 1 of 25, by Jed118
I had something similar occur - I bought an AT flip top case and inside it was a full (minus hard disk) working 386 setup.
What's for sale? my eBay!
Reply 2 of 25, by SW-SSG
The heatsink under it seems bigger than usual for socket 7. You could probably get away with running the fan at 5V and still have acceptable CPU temperatures.
Reply 4 of 25, by oeuvre
Thanks! Just bought a DVD-ROM drive to fill in that gap for cheap and a 4MB Matrox Millennium as well.
Reply 5 of 25, by oeuvre
Also I removed that IMS badge and want to replace it with a Pentium MMX sticker; know of a good place to find them?
Reply 6 of 25, by Gered
Awesome find, that case looks like it's in great shape, very clean looking!
I've bought a couple case badge/stickers from some seller on eBay that makes a bunch of 'em. The Pentium MMX badge that he sells looks good to me, but have not seen it myself in person. However, it should be noted it's the wrong size for that badge spot on your case (not a perfect square, and I think it might be just a bit too tall). Not sure if there are any other places to get these from (IMHO it would be nice to get one that matches the original sticker's little bit of colour).
EDIT: Actually here you go: https://www.ebay.com/itm/Original-Intel-Penti … 31/112625595502 (never bought from this guy so cannot vouch for him ... might be others available too).
486DX2-66/16MB/S3 Trio32 VLB/SBPro2/GUS
P233 MMX/64MB/Voodoo2/Matrox/YMF719/GUS CD3
Duron 800/256MB/Savage4 Pro/SBLive (IN PROGRESS)
Toshiba 430CDT
Reply 7 of 25, by oeuvre
Bought the 2nd one you linked, thank you!
Finally have some more time today to play around with it. Work gets in the way
Reply 8 of 25, by oeuvre
Oh yeah, one more thing. It arrived like this, the pictures didn't really show the front bezel having some plastic worn off. Any ideas how to fix it or source a replacement bezel?
Reply 9 of 25, by BitWrangler
Well I could be your buddy and tell you to forget it and look out for a new one, or I could be evil and tell you to look up "ABS repair LABS" on youtube (may involve camper roofs, principles the same)
Reply 10 of 25, by oeuvre
Upon closer inspection I could just replace the front bezel which would work fine. Sourcing them is the issue.
Reply 11 of 25, by oeuvre
Well, well. Found an 80mm fan in a drawer lying around and stuck that onto the heatsink, replacing the loud Cooler Master fan. Runs much quieter.
And replaced the Trident 2MB TGUI 9860-1 video card with a Matrox Millennium 4MB.
Reply 12 of 25, by feipoa
What I would like to know is how you managed to get this for $50 shipped. Wouldn't shipping alone be $50? I know Americans get everything for about half the cost of everyone else, but this still has me mystified. Have US shipping rates dropped? Did the guy sell it for 1 cent? Does it have something to do with the new America-first legislation in which shipping within the USA is free?
That case badge you posted, https://www.ebay.com/itm/Original-Intel-Penti … 31/112625595502 , for a $2 sticker, he wants $75 to ship it to Canada.
Reply 13 of 25, by cliffclaven
I may have to do something similar, although I have a much smaller heatsink on my P1 233. Can you put up a pic of how you rigged the 80mm fan to it? I'm assuming the mounting holes are spaced wider than the heatsink.
Reply 14 of 25, by Gered
Oh wow, I didn't look at the shipping cost when I posted that link.
Toshiba 430CDT
Reply 15 of 25, by oeuvre
I just put one screw through a corner hole of the fan... it sticks out but it works.
Reply 16 of 25, by BitWrangler
The other way to do it is find a flowerpot or soda bottle that works well as a duct. There's some plumbing parts work too, like 3" to 2.5" 45* adapter. There is actually a huge problem with dead spots in the middle under the fan motor, you know, right where the die and all the heat is.... which is why copper based sinks help hotter CPUs... and offset fans or ducted down fans can help with this. I found actually that I could cool an overclocked AXP with a 1st gen duron (sub 1ghz) aluminum based sink, with a mere 25cfm blower, because i) it blew right in the middle of the sink and ii) blowers have 3 times the pressure of fans at least, so instead of the air stalling on the top of the fins it was actually penetrating well into sink.
Reply 17 of 25, by Jade Falcon
Rank BANNED
BANNED
I shipped full size AT case and older server atx cases for around 20$. If you buy your shipping label on paypal you get a good discount. And if you ship usps parcel select you can save alot of money. But not every plcae is so cheap, I shipped cases were the cost was well over 100$.
Its all about the shipping zone your in.
Reply 18 of 25, by BitWrangler
There's also the Greyhound trick, great for larger/bulkier but short of needing a skid and forklift items, seller drops off at greyhound terminal, you pick up at your greyhound terminal.. travels in the back of a bus. It's sorted from one bus to another usually so handling ( i.e. dropping, being kicked down ramps etc) is minimised.
Reply 19 of 25, by oeuvre
Bit of an update, no progress on repairing the damage but it does have a 5.25" floppy drive now
