Matrox Mystic and m3d.
First post, by raver100
Just got my 200mmx machine working after many years.
I had a voodoo card and a 2d card in there before but they died years ago.
In my stack of old kit i has a mystic and m3d cards which i have now installed, loaded wc3 and its really jumpy in flight is this a fault with the matrox card?
Any help appreciated.
Reply 1 of 6, by konc
I don't know what wc3 stands for, if it has Glide or SGL support, so I'm speaking generally.
m3d is cpu-hungry and, unlike early Glide games where a P1 MMX + V1 are enough for some descent gameplay, this is not the case for SGL games. A much, much more powerful processor is needed for an m3d to really deliver.
Reply 2 of 6, by raver100
sorry wing commander 3.
ok i might go on hunt for a voodoo card again.
I have a voodoo banshee here but its agp so no use to me.
Reply 3 of 6, by swaaye
Wing Commander 3 doesn't support 3D acceleration. It's designed to run acceptably on a high end 486. Pentium MMX 200 and Matrox Mystique should run it smoothly in SVGA mode. Does it run super buttery smooth in plain VGA resolution? It should.
If you're expecting it to run at like 60 fps, that will never happen with a Pentium 200. I'm not sure the game engine can run that smooth anyway. It's a bit strange in how it feels and it might have a frame rate limiter.
Reply 4 of 6, by raver100
it jerks as it does in commander keen ships flicker on and off
Reply 5 of 6, by Dirk Daring
If you're trying to play in DOS.... I've found in my own experience that Matrox cards have horrible DOS compatibility..... the jumpiness and jerkiness reminds me of how my own G400 handles Jazz Jackrabbit and Commander Keen..... 🤣 just don't use these cards in DOS...... They're excellent Windows cards though!
Reply 6 of 6, by dr.zeissler
btw. Mystique has better dos-compatibility then G100/200/400.
