First post, by jholt5638
I'm trying to get WFW going on my Thinkpad a22m. Using the VGA driver works as expected but when I tried the patched SVGA driver it loads fine but dragging the mouse causes the screen to redraw the toolbar over and over I can click on things but once the mouse cursor is moved it draws over the graphics min and restoring the window things are normal until i drag over it again. the cursor seems to have a transparent box around it. I've seen similar glitches in older Linux distros and the fix was ether enable or disable hardware cursor depending. Is there a option like in 3.x?
Thinkpad A22m (P3-M 1GHz, 512MB PC100, 60GB HDD, Ati Rage Mobility-M1, Dual Sound Cards Intel AC97 & Crystal Soundfusion 4624). The OS is a heavily patched Windows 98SE (98lite Sleek Install, NUSB 3.3, USP 3.57, 98SE2ME, SH95UPD, Kernelex, and 98MP10)
