First post, by lfan
How can I setup the DOSBox ECE to use the CRT.D3D.br shader?
Thanks!
Reply 1 of 10, by Yesterplay80
Easy: You can't! DOSBox ECE doesn't support Direct3D and shaders.
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 2 of 10, by lfan
And OpenGL shaders?
DOSBox SVN Builds
Thanks.
Reply 3 of 10, by Yesterplay80
Neither, the patch that would enable those totally interferes with the one enabling the pixel perfect scaling, without some development power ECE won't see shader support anytime soon. Sorry!
Reply 5 of 10, by KainXVIII
But i thought that implementing SDL2 will make pixel-perfect patch better (or so i heard 😀 ) and maybe shaders will work too..
Reply 6 of 10, by spiroyster
Surely the pixel perfect thing sounds like a perfect candidate for a fragment shader? Or maybe not, idk, not sure how it works... whats the algorithm? o.0
Reply 7 of 10, by exofreeze
well, now that pixel perfect is gone from ECE, there isn't much excuse anymore.
Reply 8 of 10, by Yesterplay80
exofreeze wrote on 2020-09-05, 17:02:
And yet I have one! 😉
Since OpenGL shaders are built into DOSBox now anyways, there's no need to add D3D ones as well, imho.
Reply 10 of 10, by exofreeze
😉 thanks guys
