Awe32 in dos : no FM sound
Reply 20 of 41, by BloodyCactus
It shouldnt be, but maybe since the OP is running win98 and trying to set it up in dos, he is having PnP issues.
I would go into bios, and set aside dma 1/5, irq 7, as legacy if OP's bios allows, so OP can manually assign those defaults and computer wont hand them out to other things.
Reply 21 of 41, by tyrell
Note that the previous card was an als4000 and that it was perfectly working under dos ... No hassle and FM sound was working as well (of course, not a genuine opl3 like on the awe32).
Some more progress this evening if I have some spare time...
Reply 22 of 41, by derSammler
That's because the ALS drivers are really well made. They install real-mode DOS support even if you install the Windows drivers only.
Reply 23 of 41, by dr_st
tyrell,
I just realized that I never saw the exact model of your AWE32 (CTxxxx) in this thread. Did I miss it, or did you really not specify it?
Reply 24 of 41, by tyrell
Hello !
My model is ct3980.
I played a little bit in the bios options as well, a bit too much in fact, up to the point where I don't have any sound at all in dos!
My motherboard is pnp compatible, and I can set every interrupt to either Isa pnp or legacy isa. Same for the dma channels.
What should I specify there ? And there's a pnp option for the os. Should I set it to yes or no ?
Thanks for your help.
Stéphane
Reply 25 of 41, by dr_st
It would help if you generally shared more information instead of keeping us guessing all the time.
1) What is the exact motherboard model?
2) Please post the contents of your Msdos.sys, Config.sys and Autoexec.bat files.
Generally, for a PnP card such as this, I would keep all IRQ at "PCI/ISA PnP". I think "PnP OS" does not matter much, and don't remember if I have it set to 'yes' or 'no' on my Win98SE system.
Reply 26 of 41, by tyrell
The motherboard I'm using is an Aopen AX5T.
I've setup all irq and dma channels to PCI/ISA PnP (I had to reconfigure some cards in win98 afterwards)
Still no FM sound in dos ...
I tried executing the ctcm utility I have found in a sb16 archive, but it crashes and freezes the computer (restart required).
Config.sys
DEVICE=C:\WINDOWS\HIMEM.SYS
LASTDRIVE=E
FILES=80
BUFFERS=10
DOS=HIGH,UMB
rem DEVICEHIGH=C:\WINDOWS\EMM386.EXE RAM I=B000-B7FF I=C800-EFFF HIGHSCAN /MIN=0 /V
DEVICEHIGH=C:\WINDOWS\EMM386.EXE RAM I=B000-B7FF /MIN=0 /V
REM ****** CDROM DRIVER
DEVICEHIGH /L:2 =C:\DOS\oakcdrom.sys /D:mscd001
SHELL=C:\COMMAND.COM C:\ /p /e:2048
rem devicehigh /L:1 =mcam18xx.sys
rem devicehigh /L:1 =C:\WINDOWS\COMMAND\EBD\aspicd.sys /d:ASPICD0
device=C:\WINDOWS\COMMAND\display.sys con=(ega,,1)
Country=033,850,C:\WINDOWS\COMMAND\country.sys
Autoexec.bat
SET CTSYN=C:\WINDOWS
REM ***** AWE32
SET SOUND=C:\AWE32\SBAWE32
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
SET MIDI=SYNTH:1 MAP:E MODE:0
C:\AWE32\SBAWE32\DIAGNOSE /S
C:\AWE32\SBAWE32\AWEUTIL /S
C:\AWE32\SBAWE32\SB16SET /P /Q
REM ***** CDROM
LH C:\windows\command\MSCDEX.EXE /D:mscd001 /l:e
lh C:\windows\command\bin\ctmouse.exe /R11
lh C:\windows\command\doskey.com
SET PATH=C:\WINDOWS;C:\WINDOWS\COMMAND;C:\DOSMAXI;%PATH%;G:\BORLAND\CBUILDER\BIN
PATH=C:\WINDOWS;C:\WINDOWS\COMMAND;G:\BC5\BIN;%PATH%;c:\NC
mode con codepage prepare=((850) C:\WINDOWS\COMMAND\ega.cpi)
mode con codepage select=850
keyb fr,,C:\WINDOWS\COMMAND\keyboard.sys
Msdos.sys
[Paths]
WinDir=C:\WINDOWS
WinBootDir=C:\WINDOWS
HostWinBootDrv=C
[Options]
BootMulti=1
BootGUI=1
DoubleBuffer=1
AutoScan=1
WinVer=4.10.2222
Reply 27 of 41, by dr_st
I see that you have BootGUI=1, which means Windows loads by default. And my understanding is that in Windows, your sound card works fully.
When you say it does not work in pure DOS - how to you get to it? By pressing F8 during startup and choosing 'Command prompt only' or by executing 'Restart in MS-DOS mode'? In the latter case, please check what's inside DOSSTART.BAT.
Your card works in Windows, so I assume there is no hardware fault. But it's very strange that CTCM crashes.
Let's try to take it step by step:
  1. Remove all SB-related stuff from Autoexec.
  2. Boot to pure DOS (easiest way is to temporary set BootGUI=0 in Msdos.sys)
  3. Run DIAGNOSE and navigate the GUI to test the card
  4. Run CTCU, find the card under PnP cards, navigate and test its settings
  5. CTCU should update some settings and save them into CTPNP.CFG.
  6. Now run CTCM. What happens?
Reply 28 of 41, by tyrell
Hello !
I've setup bootgui=0
When I want to run ctcu, I get an error :
Cannot be run under win95 or win32.1 dos box 🙁
I'm stuck, again ...
Could you point me to the right direction ?
Thanks
Stéphane
Reply 30 of 41, by derSammler
Then you are not running plain DOS but a DOS box in Windows.
Reply 31 of 41, by dr_st
No, it's a bug in CTCM/CTCU. Read the write-up in the link.
Reply 32 of 41, by tyrell
I have updated the winbootdir to something else but I still get the same error message when running ctcu 🙁
Ok guys, I think it's becoming too complicated for me. I have ready spent a vast amount of time trying to get this card working in dos and still no results... I'm quite desperate to say the least.
Thanks anyway for your help.
Stéphane
Reply 34 of 41, by tyrell
Well the trick I used is modify the winbootdir inside msdos.sys. changing it is working. But putting an empty value does not work (still retains original value when in dos).
When in dos, if I try set winbootdir=, value is not updated. It's just ignored...
Reply 35 of 41, by dr_st
Interesting. Maybe this method is not good (don't remember if I actually tried it).
Try using the modified utilities in the ZIP I just uploaded (they implement solution #2).
Reply 36 of 41, by tyrell
Thanks for the utility !
I was able to use it.
Everything seems fine.
What I noticed:
- After running the utilities, still no fm sound in games
- If I run a full diagnose, and if I test the FM sound inside of it, then I get FM sound in games, but volume is very low.
- diagnose /s is not enough
- Mixerset and sb16set both return errors: sb16set returns a "low level driver error" error and mixerset returns "Incorrect AUXDRV.DRV driver version" error
If you are able to help me about the mixer error, i'm pretty sure i'll have fm sound afterwards... I think my problem is coming from a disabled / mutted fm output.
Stephane
Reply 37 of 41, by Jo22
In CTCU (?), did you try out different settings for FM ?
I recall that one of my PnP cards from Creative required "configuration no 2"
to be selected, in order to get FM sound working (configuration no.1 had no AdLib ports listed).
Reply 39 of 41, by tyrell
BloodyCactus wrote:
did you run mixer setup in your autoexec?
I didn't run the mixerset in autoexec.bat
When running it in command line mode, it gives a driver error ...
==> - Mixerset and sb16set both return errors: sb16set returns a "low level driver error" error and mixerset returns "Incorrect AUXDRV.DRV driver version" error
