First post, by telecommand
Hello! Need a bit of help please.
I have Windows 95 installed on an old PC of mine. For some reason I can't get the default directory to save for when I boot to DOS. It keeps booting to C:\WINDOWS\ but I want it to boot to C:\GAMES\.
I've attached the .PIF file I use - I've set it up as per Phil's DOS menu tutorial. I edited one of the lines to setdefaultdir=c:\games or something like that (can't tell you exactly right now as I'm on a Win10 PC sorry,) but no matter what I change, it always boots to C:\WINDOWS\.
Is there a setting I'm missing somewhere or something I need to edit in the .PIF file to get this to boot to the right directory? If anyone could let me know what to change, or upload a fixed .PIF file for me I would be forever grateful 😊
Thanks in advance!
Exit To Dos.PIF
2.25 KiB
45 downloads
Reply 3 of 6, by KCompRoom2000
telecommand wrote:
Hmm I don't see a dosstart.bat anywhere..?
AUTOEXEC.BAT and DOSSTART.BAT aren't always generated by Windows 95 installations. If you don't see DOSSTART.BAT inside your Windows folder, you can create a blank text document and name it DOSSTART.BAT, edit your newly made DOSSTART.BAT file with Notepad or MS-DOS editor and add your startup commands there.
Reply 5 of 6, by skitters
Check around 3:40 into Phil's video
https://www.youtube.com/watch?v=f52bZzWs-u4
Maybe you want C:\Games typed into where it says "Working" on the .pif properties Program tab.
