First post, by Nathanrico04
Every time I try to install SimCity 2000, I get this error, this error is at the end of the installation
Did you even mount a "C:" drive?
Yes
Such mistakes in the Dosbox get me interested.
In my build it was successfull installed.
Do you tried other Builds or the current svn?
Is this a edited Disk and exists the File "info.exe" on the disk?
wrote:Such mistakes in the Dosbox get me interested. In my build it was successfull installed. […]
In my build it was successfull installed.Do you tried other Builds or the current svn?
I tried with another build, but it gave the same error
and about the files, when I downloaded the files that come in the setup are these
FYI, Abandonware isn't supported here. If you downloaded SC2k from an unofficial source, you'll have to bug them about it.
Got mine from GOG.com and that works, but I had to edit the batch file to rem the intro.exe command since that requires a CD, which I don't have.
wrote:wrote:Such mistakes in the Dosbox get me interested. In my build it was successfull installed. […]
Is this a edited Disk and exists the File "info.exe" on the disk?and about the files, when I downloaded the files that come in the setup are these
You see? Where is info.exe ? I cant see it. The installer cant find it. Copy Error works normal 😀 Dont use any files fronm the net. use gog, ebay etc.. 😀
wrote:wrote:wrote:Such mistakes in the Dosbox get me interested. In my build it was successfull installed. […]
Thanks for the help guys, I already managed to solve it, but I had to download it for
windows 3.1, but this is without sound 🙁
Buy it from GOG.
I also have the diskette version and installed that in DOSBox without issues (used an LS-240 USB SuperDrive on my Windows 7 laptop).
