First post, by Flare
I'm looking for a floppy or CD-based program that will allow me to make an image of my entire hard drive to a USB stick, and restore it when necessary.
A free solution would be preferred, but if it works well I'm willing to consider paid software.
It needs to be compatible with my Socket 7 motherboard (AMD K6-2 CPU) and use a USB drive to store the backups.
Thank you.
Reply 1 of 9, by Zup
Free: Clonezilla
Maybe free: Acronis True Image (payware, but there is a WD Edition that is free if you own a WD disk).
I'm selling some stuff!
Reply 2 of 9, by Flare
Zup wrote:
Free: Clonezilla
Tried Clonezilla, not compatible with my CPU. Even the old 486 version said it needed a feature my processor doesn't have.
And looking at Acronis' website, it doesn't appear to support the FAT file system nor am I seeing any results for 486 CPU compatibility.
Reply 3 of 9, by BloodyCactus
can you boot an old linux cdrom and just dd the hd to usb stick?
what I do with my SS7 box is remove its CF card, stick CF into my linux box and DD the image... (a great reason to use CF cards in retro builds!)
Reply 4 of 9, by Flare
Maybe? I've only used that tool to clone drives, not make backup images
I use CF cards so I can swap OSes more easily.
Reply 6 of 9, by Disruptor
What's about Norton Ghost?
Reply 7 of 9, by Flare
The early versions might work, but I don't see them for sale anymore. 🙁
It occurred to me that since I'm using CF cards to swap OSs, I can easily image them using Win32 Disk Imager on my Windows 10 machine.
Doesn't have the nostalgic feeling as a real backup utility from the era I'm trying to recreate, but it will work.
Thanks guys.
Reply 8 of 9, by Stiletto
Moved.
do the Fandango!" - Queen
Stiletto
Reply 9 of 9, by PC Hoarder Patrol
Have you tried LSoft Technologies Active@ Disk Image 2.1 for DOS which is free
http://www.disk-image.net/downloads/disk_img.zip
- AT compatible CPU with 386 or greater processor
- BootDiskCreator.exe - Boot Disk Creator utility. Use it to make a floppy or USB flash bootable disk containing free Disk Image for DOS software.
- disk_img.iso - Bootable ISO image for CD. If you want to boot from CD, burn this image to a blank CD and boot from it (contains free Disk Image software).
- disk_img.exe - DOS executable. Run it directly in DOS environment.
- dos4gw.exe - Auxiliary component for disk_img.exe
- disk_img.pdf - User Manual in PDF format
- license.txt - End user license agreement
