First post, by GabrielKnight123
Hi all, I have an ISA Input/Output controller card that has the name "Super I/O Card" and I have connected the 1.44mb floppy drive and IDE hard drive as master and the DVD drive as Slave but the DVD drive is not being detected im wondering if this is a limitation of the controller card as I have tried another I/O card and the DVD drive works but since my second I/O card does not have a com port for a serial mouse and the Super I/O card does have a com port I have tried to connect both cards at the same time but with both connected the Super I/O card stops the second I/O card from detecting the HDD, I have tried using different ISA ports but it does not help. The 486 motherboard im using does not really have any options in the bios for IRQ settings.
