First post, by Tails19935
Hello, I'm a long time viewer but this will be my first time posting. This is going to be lot to read but bear with me... 😅
I recently found out about the Guillemot Maxi Sound and the Terratec EWS64 bank soundsets. I have been trying to figure out how to convert these .94B/.94K/.94I files into SF2 so I could use them in my own music. Unfortunately, these file formats are REALLY old so most of the info for these formats are from years ago and many links become almost unavailable if not broken from sites going defunct over time. I had to use The Wayback Machine for most of what I could get. From all the info I could find...
TTI Converter 2.02 can convert TTI files to SF2 but not TTS files. However, a user does claim it can work with it. It wouldn't load the file for me.
http://www.hostboard.com/forums/f693/61925-tt … conversion.html
http://www.hostboard.com/forums/f693/38765-pr … -soundsets.html
Vsample 16 can convert .94b files. Couldn't get a working link. Tried newer versions and they don't support the files. https://www.kvraudio.com/forum/archive/instru … 001-10/1175.php
Then there is the last option that I could find which is use SampleLink by Synoptic. I was able to find a demo version of the program using The Wayback but not the full program. It seems to load files but you can't convert anything because the demo doesn't allow it.
https://web.archive.org/web/20010418154622/ht … ynoptic.net:80/
https://web.archive.org/web/20061120004957fw_ … l.com/slink.htm
Extra Info: I have a program that can convert .94B files to TTS and vice versa.
These are the ways I could go about getting to SF2 if I had the right tools...
94B to TTS to DLS to SF2.
94B to TTS to TTI to SF2.
94B directly to SF2 if someone can find a full version of SampleLink.
There is also a possibility of a VST floating out there that I don't know about that can just load these files.
So far I have been working on this for quite a few days and still haven't gotten anywhere aside from importing the files into Audacity and cutting every single sample separately which I really don't want to do. 😢
So please, let me know anything you guys might have tucked in a hard drive somewhere or have knowledge regarding this topic.
Extra Links:
https://www.kvraudio.com/forum/viewtopic.php?t=43372
http://www.hostboard.com/forums/f693/38834-co … -files-tti.html
.94B sound fonts (Terratec EWS64, Maxi Studio ISIS)? Hey... a link to this site.
http://web.archive.org/web/20080314220936/htt … ubuserapps.html
