First post, by superfury
Does this default to SS or DS? Afaik base (E)SP or (E)BP do(it's mentioned as base of (E)SP/(E)BP, but not sure about the index of EBP?
Edit: https://stackoverflow.com/questions/49721801/ … s-or-ss-segment seems to imply thst the EBP as an index is the only EBP/ESP relative addressing defaulting to DS instead of SS. Was also a bug in the capstone disassembler apparently.
UniPCemu Git repository
