First post, by GabrielKnight123
Hi all, I found a heatsink and fan here at home that will do the job quite well to go with my AM5x86-P75 CPU but I need a thermal pad to stick it to eachother, would it be best to use a 1mm pad or a 0.5mm pad I dont know but wouldnt the 0.5mm be better for heat transfers because of the thickness?
I found these:
https://www.pccasegear.com/products/29189/ek- … hermal-pad-1mm/
https://www.pccasegear.com/products/29192/ek- … al-pad-b-0-5mm/
Or is this the wrong type of pad?
Reply 1 of 5, by SW-SSG
If the idea is to stick a clip-less HSF to the CPU, these won't work; they aren't adhesive.
Reply 2 of 5, by GabrielKnight123
Im not sure which one I need then can you give me a link to one that is adhesive?
Reply 4 of 5, by The Serpent Rider
Just use sticky thermal paste like Arctic Cooling and reinforce it with small amounts of adhesive near the corners of CPU.
Reply 5 of 5, by oeuvre
thermal pad thiccness
Serpent's suggestion is a solid one.
