First post, by MitAvras
Hello! I have troubles while trying to change the Options of DOSBox. Each time I try to open the DOSBox Options, nothing happened and although I change the options manually, when I start DOSBox, it starts with its default settings. My PC Configuration is:
CPU : Intel Core i-7 6800K @ 3.40 GHz
RAM : 64 GB @ 2.400 MHz
GPU : nVIDIA GeForce GTX 1070 @ 8 GB DDR5
O/S : Microsoft Windows 10 Pro 64bit
Can you tell me why does it happen and how can I solve it?
