The Serpent Rider wrote:Not possible, they are usually compatible only with 440FX chipset boards. […]
a Pentium Pro with SD-RAM and AGP videocard
The full speed cache is nice, but any 300Mhz+ PII will likely beat it in most gaming benchmarks.
Even Mendocino will run circles around it, so it's entirely pointless adapter for extremely laughable price.
I think I read that some 440LX boards also supports Pentium Pro but only with early BIOS releases. I'm not really sure where I picked up that information though and it's not something I have tried my self.
But as you can take a Tualatin PIII and stick it on some Pentium Pro Socket 8 motherboards (with a stack of adapters) and make it work with a BIOS from 1996 (5 years before the Tualatin was released) I would actually find it odd if you couldn't get a Pentium Pro running on a BX board even if it isn't properly recognized. I was a bit surprised when the BIOS on my Gateway branded (Intel) VS440FX Socket 8 motherboard successfully identified and activated the Tualatins L2 cache.
Here is a screen dump showing a Celeron 1400 @933 running on the VS440FX Socket-8 board with a BIOS dated December 5th 1996.
