First post, by voodoo47
the motherboard connector has a proper notch so no chance of messing up at that end, the drive however doesn't, so it would be great if someone could confirm whether I'm doing this right - the drive has no markings indicating where pin1 is, google image search suggests pin1 should be next to those extra four pins that are not used by the cable, but better safe than sorry (almost sure that if connecting this incorrectly, pretty much everything will end up dead). also, does anyone know which pins actually carry power? //ah, should be the ones at the opposite end.
thanks.
