First post, by abi
Through cross compilation i created a dosbox binary file.when i try to execute dosbox in RZ/G1E (./dosbox),first i faced libraries issues then i rectified all the library issues after this it throwing a error "detected fb_set_par error ,error code: -22" how to rectify this.
root@SM-G22M:/# cat /etc/issue
Rootfs Version : iW-PREZZ-SC-01-R2.0-REL1.0-YoctoDaisy
Poky (Yocto Project Reference Distro) 1.6.1 \n \l
root@SM-G22M:/# ./dosbox
FastDOSBox version CVS
Ported by Norisc-NoFun, Based of DOSBox source code.
Copyright 2002-2011 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file /home/root/.config/fastdosbox/fastdosbox-CVS.conf
"dynamic" is not a valid value for variable: core.
It might now be reset it to default value: dynamic
detected fb_set_par error, error code: -22
Exit to error: Could not initialize video: Couldn't set console screen info
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
you might be at the wrong place.
This is the support for DOSBox. Not fastdosbox.
Water flows down the stream
Reply 2 of 3, by olddos25
I bet DosFreak is gonna close this topic now.
Just another user that likes old OSes and videogames, nothing interesting to see here...
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
Reply 3 of 3, by DosFreak
That unofficial version of DOSBox is very old. Did you try a later ver of DOSBox from whatever repo that OS uses? T
Think the last benchmarks I looked at was that the Pi could run low end 486 games unknown how well they run though.
Make your games work offline
