First post, by Spiky
Making Win95 work in DOSBox was relatively easy task to do (on my Windows 10 desktop). Running games was no problem, performance was pretty good as well.
However, my plan was to move it to Pi3, RetroPie. Now to achieve this, I had to remove COM1, COM2, LPT1 drivers, otherwise the only way to run Win95 there was from safe mode. At the moment, it boots without any issues. Problems start when I try to run anything. I tried to run Dangerous Dave (the first one, from 80s), but Win95 crashes right as start of the game. Next time, I decided to try to run it from command line, but it got frozen as soon as the command line appeared. I also did few changes to DOSBox config (on both machines, on Win10 desktop works just fine) - machine=svga_s3,core=normal,cputype=pentium_slow.
I am well aware of the fact that DOSBox was not made for running Windows95, still, I would really appreaciate if anyone could help. Thanks
Reply 2 of 5, by Spiky
I am well aware of that. What I hoped for was that someone tried to do the same as me and managed to get further.
Reply 3 of 5, by leileilol
When we mean "Windows 95 is not supported" here, we really mean it in every aspect possible*
* except for running DOSBox from within Windows 95
Reply 4 of 5, by Spiky
I am happy to tell you I finally managed to make it work. Tried to run several games under it and it works pretty good. I will put together guide and place it into https://retropie.org.uk/forum/ , so if anyone is interested in making Win95 work in RetroPie, you can follow me there.
Looks like the most you can get out of this place is the knowledge that something is impossible. At least I know where NOT to go when seeking for help. Thanks
