First post, by ultra_code
Hello VOGONS memebers!
I have a simple question. I have been experiencing this weird loading screen glitch in Need for Speed 3 for quite some time on my Voodoo3 machine. Is this an indicator that there's something wrong with the game itself, or is it my Voodoo3 that I should be worried about?
https://youtu.be/0KZQNTB6208
Any help would be appreciated. Thanks!
Builds
Reply 1 of 5, by 3dprophet
Could it be due to the overclock?
Reply 2 of 5, by ultra_code
My apologies for taking 3 days to respond. Usually respond much faster than that.
Yes, I do have my card overclocked. It used to be at around 196 or 198MHz (can't remember), and then, after redoing the benchmarks at higher resolutions later on, I realized that that was unstable, and so found that 192 was stable. Of course, I dialed that to 188, and just a few days ago, I thought it would be wise to dial it back to 180. If you are curious, the card is being cooled by a nice Noctua fan that I have zip-tied onto the card's heatsink, and later, I might decide to thermal tape some heatsink onto the memory chips.
Now, I did go ahead and test whether it was the overclock or not. The original clip I showed was the card overclocked to 180MHz playing the "modern patch" version of NFS3 (using the original game files from my copy of the vanilla game). This following video is with the card at the same overclock, but playing the vanilla game:
https://youtu.be/l7uIw_Aq_Uk
I then tested both versions of the game at the default, stock 166MHz clock, and the same results presented themselves for each game respectively.
Builds
Reply 3 of 5, by ultra_code
Any ideas?
Builds
Reply 4 of 5, by buckeye
Could try the Need For Speed III Modern Patch v1.6.1 - worked for me on my V2 system which was locking up AFTER a race.
Reply 5 of 5, by ultra_code
But I am already using the modern patch (http://veg.by/en/projects/nfs3/): That's why I have provided two video links - the first one being me playing the game using the modern patch, and the second one without.
Builds
