I don't think that is true for all Intel 486 DX4s. This is from the "EMBEDDED WRITE-BACK ENHANCED
IntelDX4™ PROCESSOR" datasheet from October 1995:
And this if from the "Am486® DX4 3-Volt Processor - High-Performance, Clock-Selectable, 3.3 V, 32-Bit Microprocessor" datasheet from July 1995:
It seems AMD even copied the datasheets...
But you never know. A little story on the side, I hope the TO doesn't mind if we deviate a bit from the thread's topic.
I recently acquired a Biostar MB-8500TVX Socket 7 main board. It was designed at a time when MMX processors where announced but not available yet, but it stated it would support them (i.e. providing split voltage support).
I had an AMD K6-200, a P200 non-MMX, and a P200-MMX to try it out. All of them worked, but the P200-MMX was only running at 166MHz, while the other 2 CPUs were running at 200MHz with the same multiplier jumper settings. I suspected that one of the BFx pins of the CPU was defect until I found this:
The board obviously pulled the BF down when the jumpers were set and left them floating when the jumpers were not set. (I confirmed by measuring it btw.) To overcome the limitation with the P200MMX I soldered in 2K2 pull-up resistors to BF0 and BF1 and now my P200MMX runs happily at 200MHz.
I think there were so many CPU types from so many manufacturers during the Socket3 to Socket7 period that it is nearly impossible to know everyone of them. But that's part of the fun, isn't it? 😀
