First post, by Glook
i had discover a old DOS pinball game : Steelshot
https://www.youtube.com/watch?v=Am-hlBsbNyE
I have issue with this game, it doesn't run under dosbox, but run under virtualbox (too fast but it run !)
it freeze on start :
could anyone help me, please ?
Reply 1 of 7, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The hang is apparently caused by DOSBox not correctly emulating a keyboard command code. I think it's easy to fix, but need to do some testing.
Reply 2 of 7, by Glook
it sound good, how and what can i test ?
Reply 3 of 7, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Should be fixed now, at revision 4170.
Reply 4 of 7, by Glook
okay, anyway to play this game on Dosbos 0.74 ?
Reply 5 of 7, by lightmaster
0.74 needs an asm or a tsr fix (loader), maybe someone can do it with time.
Reply 6 of 7, by ripsaw8080
Rank DOSBox Author
DOSBox Author
It's a hardware emulation issue, so you have to hack the game code while avoiding an anti-hack check. If you're comfortable with using a hex editor, in the installed copy of SHOT.EXE modify the byte at offset 7A682 from 00 to EF, and the byte at offset 7A686 from EF to 00. It's the latter byte that bypasses the hang, while the former balances the anti-hack checksum. Maybe easier to just use an SVN build, though. 😉
Reply 7 of 7, by Glook
wooowww ! very impressive !
it works, thanks !!!
