Prometheus ARIA16
First post, by i2lgames
Hello guys and a very happy new year! I found a Prometheus ARIA16 and tried to make it work with no luck. It booms when i turn on my pc and then silence... I noticed that everything in the from of the card is where it should be but in the back it's missing the L2,L3,L4. Can someone who has this card take a picture of the back side so i can make sure that i am not missing something?
Many thanks.
Reply 1 of 9, by Tiido
L2/3/4 were never there and you can see they two are clearly bypassed and 3rd one probably is too so this will not be the cause.
The contacts look fairly dirty, go over them with a pencil eraser. Do you have the initialization software / driver etc. ?
Reply 2 of 9, by i2lgames
I used the driver from VOGONS for the very same card. No luck! Also i tried the windows driver with no luck.
Reply 4 of 9, by i2lgames
I tried the gateway THOR 2000 socket 7 with pentium 233 mmx and 32mb edo ram also a slot one ABIT BH6 pentium 3 550 256mb sdram
both run dos 7.1 and windows 98se
Reply 6 of 9, by bristlehog
It seems that Prometheus ARIA16 cards wouldn't work on machines faster than 486.
Hardware comparisons and game system requirements: https://technical.city
Reply 7 of 9, by Logistics
Did you check the big, shrink-tubed fuse? F1?
Reply 8 of 9, by i2lgames
I did not know that! I will undig my 386 and my 486sx/33 to test further!
Reply 9 of 9, by i2lgames
Yes! It was one of the first things i tested. It has continuity.
