First post, by ZellSF
Says "soundcard not found" or something like that. Mostly default config, except Gravis Ultrasound emulation was enabled.
When trying to run it through VDMSound, I still get nothing, but it doesn't give any error message. The last line is "TFMX:5"
Using a CVS version of Dosbox... Tried with 0.63 just to be sure, same result.
