First post, by cxm717
- Member
OK, so I did a driver comparison on a TNT2 (125/150) under windows 98. I thought I would share the results here.
I used a P3 800/133 on an intel OR840 board with 512MB of 800MHz RDRAM and a sound blaster live sound card. I wanted to run these benchmarks on my 440BX board but the TNT2 was just not stable at 133MHz/89MHz. I also tried the TNT2 with the same drivers in a K63 450 setup in an ASUS P5A-B with 128MB of PC100@CL2 and a sound blaster live card.
The P3 results:
The K6-3 results:
Edit: Forgot to add a few things. I'm going to add some 1999 games later. The K6-3 setup was a bit unstable with the 53.04 drivers and it would not even load into windows with the 61.76 driver.
