First post, by _ar
Do any one of you have the manual for the Rev 1.7 by any chance? I only found jumper settings for the rev 1.1 and 2.0 board, but the 1.7 looks different. Any help is appreciated! Thanks!
Reply 1 of 4, by TheMobRules
A while back I made a post regarding version 1.8, it has details on what certain jumpers do. I suppose 1.7 is pretty much the same:
ASUS VL/I-486SV2G(X4) REV. 1.8 conversion and jumpers guide
I only mention the jumpers that are different, the rest should be the same as on the 2.x manual.
Reply 2 of 4, by _ar
Thanks, TheMobRules! Just for reference, would you please confirm that the cpu jumper block on the 1.8 looks exactly like this? (6,6,5,5,5 pins from the top) Thanks!: rev17jumpers.jpg
Reply 3 of 4, by TheMobRules
Yes, looks identical to mine.
Reply 4 of 4, by _ar
Thanks! I also found that the jumper setting for the rev 1.1 pretty much applies for the 1.7 as well.
