I/O delay
First post, by Grunt
Hello guys,
I've been trying to slow down I/O (especially disk reading) so I can emulate real I/O responses from old computer in DosBox. I've notice that such a thing is alredy implemented and used in DosBox.
dos/dos.cpp:
71: #define DATA_TRANSFERS_TAKE_CYCLES 1
72: #ifdef DATA_TRANSFERS_TAKE_CYCLES
73:
74: #ifndef DOSBOX_CPU_H
75: #include "cpu.h"
76: #endif
77: static inline void modify_cycles(Bits value) {
78: if((4*value+5) < CPU_Cycles) {
79: CPU_Cycles -= 4*value;
80: CPU_IODelayRemoved += 4*value;
81: } else {
82: CPU_IODelayRemoved += CPU_Cycles/*-5*/; //don't want to mess with negative
83: CPU_Cycles = 5;
84: }
85:}
procedure modify_cycles() is then called from reading and writing into file:
644:	case 0x3f:		/* READ Read from file or device */
645: {
646: Bit16u toread=reg_cx;
647: dos.echo=true;
648: if (DOS_ReadFile(reg_bx,dos_copybuf,&toread)) {
649: MEM_BlockWrite(SegPhys(ds)+reg_dx,dos_copybuf,toread);
650: reg_ax=toread;
651: CALLBACK_SCF(false);
652: } else {
653: reg_ax=dos.errorcode;
654: CALLBACK_SCF(true);
655: }
656: modify_cycles(reg_ax);
657: dos.echo=false;
658: break;
659: }
Unfortunately, I can't figure out how it works. I/O read and write is definitley slower with modify_cycles (respectively disk I/O with DATA_TRANSFERS_TAKE_CYCLES 0 is fast as a lightning on modern PC) but it is still not enough. Even if I just try to leave CPU_Cycles = 5; there hardcoded.
I did found a way, which is SDL_Delay:
78: SDL_Delay(10);
79: if((10*value+5) < CPU_Cycles) {
80: CPU_Cycles -= 10*value;
81: ....
This works how anticipated. But it is not correct way how to delay execution. Entire DosBox app is delayed (including drawing functions, recording, etc.), not just execution of virtual machine.
So question follows: Which is proper way how to slow down or delay execution of core (VM?) in DosBox? Lets say in order hundreds of milliseconds or even whole second, not just a few cycles. Just so I can emulate seek times of old HDD or floppy disks.
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
Not a clear answer for you, as I have stumbled with it a few times a well.
But take a look on how BEEP is implemented or int14_wait.
That shows a way to pause the system without blocking the entire machine, but it is not really ideal.
Water flows down the stream
Reply 2 of 4, by Grunt
Ok, so answer is CALLBACK_Idle();. Now it is not exactly how do I remember it, it's even better:
file.php?id=65586&mode=view
It is perfect. Thanks a lot.
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
what did you end up using ? how many milliseconds ?
Reply 4 of 4, by Grunt
Just a random number of calls for given cycle speed:
int i;
for (i=0;i<80;i++)
CALLBACK_Idle();
  • i<10 - too little
  • i<100 - too much
  • i between 40 and 80 - just fine for me.
Only as I said, some of the games uses either case 0x3f: /* READ Read from file or device */ or case 0x40: /* WRITE Write to file or device */ while writing text on screen or somehow else end up in modify_cycles() and they shouldn't. Vanilla DOOM for example uses direct writing on screen and works just fine (modify_cycle() is used only for real disk I/O - notice the flickering floppy disk):
file.php?mode=view&id=65655
There is no reason to require some milliseconds anyway. CALLBACK_Idle() stalls execution for pretty long to require accuracy in order of milliseconds.
Only except...are you sure CALLBACK_Idle is the right guy for the job?
void CALLBACK_Idle(void) {
[u]/* this makes the cpu execute instructions to handle irq's and then come back */[/u]
Bitu oldIF=GETFLAG(IF);
SETFLAGBIT(IF,true);
Bit16u oldcs=SegValue(cs);
Bit32u oldeip=reg_eip;
SegSet16(cs,CB_SEG);
reg_eip=CB_SOFFSET+call_idle*CB_SIZE;
DOSBOX_RunMachine();
reg_eip=oldeip;
SegSet16(cs,oldcs);
SETFLAGBIT(IF,oldIF);
if (!CPU_CycleAutoAdjust && CPU_Cycles>0)
CPU_Cycles=0;
I'm not sure.
