First post, by jomalin
i am on a Win10 64 bits machine running last version of Dosbox (0.74-3).
Trying to run the shareware game Chelu 3:
https://archive.org/download/Chelu/Chelu.zip
does not work in Dosbox, it executes well but then in the middle of the intro screen it gets freeze and this log is shown:
Illegal read from 45021405, CS:IP f000: 11c4
Illegal write to 8b2aa3fc, CS:IP f000: 11c4
Illegal read from 45021406, CS:IP f000: 11c4
Illegal write to 8b2aa3fd, CS:IP f000: 11c4
Illegal read from 45021407, CS:IP f000: 11c4
Illegal write to 8b2aa3fe, CS:IP f000: 11c4
Illegal read from 45021408, CS:IP f000: 11c4
Illegal write to 8b2aa3ff, CS:IP f000: 11c4
Illegal read from 45021409, CS:IP f000: 11c4
Illegal write to 8b2aa400, CS:IP f000: 11c4
Illegal read from 4502140a, CS:IP f000: 11c4
Illegal write to 8b2aa401, CS:IP f000: 11c4
Illegal read from 4502140b, CS:IP f000: 11c4
Illegal write to 8b2aa402, CS:IP f000: 11c4
Illegal read from 4502140c, CS:IP f000: 11c4
Illegal write to 8b2aa403, CS:IP f000: 11c4
Exit to error: DMA segbound wrapping (read)
I executed it using the default configuration of Dosbox.
Does anyone know how can this be fixed? Thanks
This game is done using the ObjGfx graphic library, you can read info about the game here:
http://www.monstersoft.com/download/
Also, this game is not added to the compatibility list:
https://www.dosbox.com/comp_list.php?letter=C
