First post, by zfishman
This works great for Old Time Baseball in Windows XP (I have not tried it on any other Windows system). 😀
Create a directory c:\oldgames
Create a directory c:\oldgames\oldtimcd
Copy the entire CD contents to c:\oldgames\oldtimcd
Open DosBox (everything below is to be done from within DosBox)
Type:
mount c c:\oldgames <enter>
c: <enter>
cd oldtimcd <enter>
install <enter>
Follow the instructions to install the game and all the voice options (Curt Gowdy and Mel Allen) to the default directory. After it says the game has been successfully installed hit <enter> which will return you to DosBox.
Type:
cd\ <enter>
cd oldtime <enter>
setup <enter>
Select "Video Card Configuration" and hit <enter>.
Select "Auto-Detect the Video Card" and hit <enter>.
Follow the instructions and accept the default.
Hit <enter> and a splash screen should show for the game. Hit <enter> to accept.
Select "Sound Card Configuration" and hit <enter>.
Select "Select and configure digital audio card driver" and hit <enter>.
Select "Creative Labs Sound Blaster 16 or AWE32" and hit <enter>.
Select "Attempt to configure sound driver automatically" and hit <enter>. You should hear Curt Gowdy's voice. Hit <enter> to accept.
Select "Done" and hit <enter>.
Select "Done (EXIT)" and hit <enter> which will return you to DosBox.
Type:
mount d c:\oldgames\oldtimcd -t cdrom
oldtime <enter>
Enjoy! 😀
You won't need the CD to run the game when these instructions are followed (you will need to keep all the files in c:\oldgames\oldtimcd that you copied from the CD on your computer). The game runs smoothly for me though the sound seems just a small bit choppy. This may be part of the game itself or perhaps some speed settings need to be tweaked, but overall it runs well.
To run the game in the future, open DosBox:
Type:
c: <enter>
cd oldtime <enter>
oldtime <enter>
