First post, by respect2759
Hi guys, I have a 386 40MHZ Soyo 019R1 board. Upgraded the ram from 4 to 8mb, has a Trident 512kb graphics card. It runs DOS and Win 3.1
Last 2-3 days I am trying to add a CD rom. My oldest one is a 16x Mitsumi from 1997. IDE is on IO card, no ports on the board. I am struggling to get it working, system dont recognise it. I dont know the jumper setting of the IO card, found PT 606E and PT 606G manual, I have a PT 606V... Tried the jumper setting of PT 606E which looks exactly like my card. Also tried to disable IDE master and connected the HDD with an old type of cable which has only 2 ends no connector in the middle and DOS just starts up normally, so I think manual is not good for my card or I am just too dumb to figure it out how to get the CD rom recognized by system... Tried master, slave cable select. Tried both ends of cable. Tried to find it in bios... Waiting for some advices or tips 😊
    1.31 MiB
    1.07 MiB
    1.22 MiB
Soyo 019R1 AM386DX 40MHz, 8Mb ram, 512Kb Trident 9000 Graphics
S26361-D756-X Intel i486DX 33MHz, 4Mb ram, 512Kb - 1Mb graphics on board
Reply 1 of 13, by derSammler
The IDE port probably does not support ATAPI. There's a reason why most CD-ROMs up to 1994 used a proprietary interface (or SCSI). IDE without ATAPI does not support anything else than hard disks.
Reply 2 of 13, by Anonymous Coward
Are you loading the CD-ROM drivers?
Reply 3 of 13, by respect2759
A CD rom needs drivers?
Reply 4 of 13, by PTherapist
Yes.
Try writing a DOS bootdisk that has CD support and boot from that to test if the drive is being detected correctly. Then you'd just need to copy the driver & executable (ie. mscdex) over to your C drive and configure them in config.sys & autoexec.bat
Reply 5 of 13, by Anonymous Coward
The windows 98 bootdisk has ATAPI CD-ROM drive support, but all you need is the OAKCDROM.SYS driver and you can stick that in the config.sys of a regular DOS bootdisk.
Reply 6 of 13, by maxtherabbit
BIOSes in pre pentium systems do not detect CDROMs and, here's the important part - it doesn't matter
The DOS CDROM driver (I recommend VIDE-CDD.SYS) will scan master and slave on both channels and pick up the drive.
The BIOS 100% doesn't matter
Reply 7 of 13, by JudgeMonroe
This is correct. ATAPI is implemented by the driver; the BIOS doesn't need to detect the drive. Some drivers support as many as 4 IDE interfaces when looking for an attached drive. The reason SCSI and proprietary interfaces were common in this era was because the systems didn't necessarily even have available IDE ports. ATAPI support in BIOS enabled "detecting" CD-ROMs (mostly cosmetic, since you still need a driver) as a coincidence along with supporting larger modern hard drives.
Reply 8 of 13, by respect2759
Thanks for advices, I found a soundcard with IDE and its compatible with Mitsumi, so I will try that. I am a hardware guy, so its easier for me this way 😀
Reply 9 of 13, by GigAHerZ
You still need a driver to be loaded in dos...
Reply 10 of 13, by jesolo
Under DOS, regardless which interface you use, you still require a device driver to recognise the CD-ROM drive.
Since your CD-ROM is from 1997, it most certainly is an IDE interface but, could possibly also be SCSI?.
Just be careful in hooking up your 1997 Mitsumi IDE drive to an older sound card from 1991-1992 that still used the proprietary Mitsumi interface. They are not compatible with each other.
Reply 11 of 13, by Matth79
The separate Panasonic / Sony / Mitsumi interfaces died out with 4x drives, if I recall... connecting an IDE drive to an old style interface may damage one or both.
If the CDROM has options of master/slave it is definitely IDE.
You may have problems with older IDE hard drives which predate standardisation of Master/Slave - some have options for different standards, or require a specific setting for "slave present"
Reply 12 of 13, by respect2759
The HDD has no jumper settings its an old quantum fireball
Reply 13 of 13, by Anonymous Coward
Err, pretty much all IDE drives had jumper settings as far as I recall. I've owned fireballs, and all of them had at least a jumper to control master/slave.
Pretty much. There were 3X drives, but I think only NEC made them and they were all SCSI. I've only ever seen 1X and 2X drives with a proprietary interface. What really throws me off are those obscure 2X drives that had an ATAPI interface.
