Running Windows NT 4.0 on a Cyrix DLC/SXL/DRx2
First post, by feipoa
Has anyone been successful or unsuccessful running Windows NT 4.0 on a DLC/SXL/DRx2 CPU? According to online information, NT4 requires a 486, I presume for the instruction set.
I have an SXL2-66 system and cloned the HDD from a true 486 system with NT4/W95 on it. On the SXL2-66 system, NT4 boots to the desktop when I try to open the Control Panel, nothing happens. If I boot in VGA mode, I just see a black screen, so I am booting in regular mode.
If someone has had success with this, I'll invest the time in doing a proper full install of NT4. If not, then I'll pass.
Reply 2 of 28, by Caluser2000
Anonymous Coward wrote:
Did you check usenet?
I think they call it google groups these days.
Reply 3 of 28, by derSammler
No. Google Groups is just an archive of old usenet posts (like archive.org is for websites). Usenet is an internet service like www, ftp, irc, etc. Google has nothing to do with that.
Reply 4 of 28, by Caluser2000
Well I would never have thought..........
Please note the sarcasm in case you missed it 😀
My understanding is that google groups archives all usenet posts. "Google began archiving Usenet posts for itself starting in the second week of August 2000."
Worth reading https://www.quora.com/Is-Usenet-dead
Anway the cool dudes use irc :p
I did a search for the OP but no matching results. Neither were there on DuckDuckGo or Bing. Zip on google as well. Those Cyrix DLC class chips were a bit odd. NT 3.51 might work. It'll be interesting to see how the OP gets on. I'd try it with my DLC but have no survicable 386 class mobos available unfortunately.
Windows NT minimum hardware requirements
Windows version CPU RAM Free disk space
NT 3.1 i386, 25 MHz 12 MB 90 MB
NT 3.1 Advanced Server i386, 25 MHz 16 MB 90 MB
NT 3.5 Workstation i386, 25 MHz 12 MB 90 MB
NT 3.5 Server i386, 25 MHz 16 MB 90 MB
NT 3.51 Workstation i386, 25 MHz 12 MB 90 MB
NT 3.51 Server i386, 25 MHz 16 MB 90 MB
NT 4.0 Workstation i486, 25 MHz 12 MB 124 MB
NT 4.0 Server i486, 25 MHz 16 MB 124 MB
Apart from the change in Ui NT 3.51 and NT4 are much the same as far as internals go.
Reply 5 of 28, by feipoa
And apparently there is a NT4 shell for NT 3.51. Still, my interest is in NT4 for curiosity, but the foremost issue is getting the Cyrix.exe cache software (and ps2suppc) loaded first, otherwise my SXL2-66 will perform like an ordinary cacheless 386 at 33 MHz. I am surprised that there isn't much information on this software and hardware combination. Were there more hits for NT 3.51 + DLC/SXL/DRx2 rather than for the NT4 combination?
Reply 6 of 28, by Caluser2000
No positive results at all I'm afraid. Turning on the speed doubling is the issue. You could may be able to have a dos fat16 partition, boot to it in Dos then enable clock doubling and caching then run NT. Have an extended partition for NTFS. I know it is possible to do similar with OS/2. The PS/2 mouse port shouldn't be an issue NT should pick that up.
Using a small fat16 partition to boot strap NT on MIPs and Alpha systems was the way things were done in the early NT days iirc.
Reply 7 of 28, by feipoa
Or even just enabling the L1 cache. Most old motherboards didn't have L1 cache support for the DLC.
Reply 8 of 28, by kixs
Interesting project 😉 I might try it...
Reply 9 of 28, by feipoa
The challenge is getting your L1 cache and 2x mode enabled properly, which is done in DOS. See this other post for some ideas, Any way to run a DOS TSR program before loading Windows NT 4.0?
Reply 10 of 28, by Anonymous Coward
Did you see my message about GRUB for DOS? I believe you can use that to boot NT4 from a DOS prompt.
Reply 11 of 28, by kixs
I plan on using DRx2 or BL.
Reply 12 of 28, by feipoa
Yup.
Re: Any way to run a DOS TSR program before loading Windows NT 4.0?
feipoa wrote:
User Anonymous Coward mentioned using GRUB for DOS. Then load GRUB from the DOS prompt to load NT4. This way I can run ps2suppc […]
User Anonymous Coward mentioned using GRUB for DOS. Then load GRUB from the DOS prompt to load NT4. This way I can run ps2suppc.com and cyrix.exe
http://xpt.sourceforge.net/techdocs/nix/disk/ … fo/ar01s03.html
2.3 Starting GRUB for DOS from DOS
You can use load GRUB for DOS in config.sys using one of the following lines:
DEVICE=GRUB.EXE
INSTALL=GRUB.EXE
SHELL=GRUB.EXE
grub.exe can also be launched from DOS prompt or batch file such as AUTOEXEC.BAT.
As this seems like it would require the least amount of effort, it is the GRUB is the first idea I intend to try. But first, I want to ensure I can install Win95c on my SXL2-66. If Win95 doesn't work, NT4 probably won't work. I have one of those SCSI2SD devices in this system. It has a 64 GB SD card in it and I can set it up such that there are numerous physical HDD's on it with different SCSI ID's. So my SCSI ID1 is an 8 GB drive, which has a 2 GB FAT partition for DOS/Windows, and a 2 GB FAT partition for storage. I could create another 2 GB partition, but I think you can only have one primary partition. So I am going to create another 8 GB hard drive on SCSI2SD using ID2, while disabling ID1. I want Win95c to be on a single 8 GB FAT32 partition. This is my goal for this evening.
Reply 13 of 28, by feipoa
But the DRx2 already has the flush circuit and 2x enabled, so it is a lot less of a challenge. Looking forward to your results.
Reply 14 of 28, by feipoa
This is what I mean with SCSI2SD. It can create up to 7 HDD's from a single microSD card.
W95c installing so far so good.
Reply 15 of 28, by GigAHerZ
Windows 95C works quite well on both 386DX-40 and 486DLC-40. (I did install it for the Cpu-Z improvement contribution)
Reply 16 of 28, by Anonymous Coward
feipoa wrote:
That's a pretty sweet dark grey CD-ROM drive. What's up with the 5.25" FDD though? Why not move it up a panel?
Reply 17 of 28, by elianda
I had a similar issues in '96 when I needed to initialize a sound card in DOS to make it work in NT4.
What I did was to install DOS then NT4, so that both OS appear in the bootmenu.
In DOS I use some config with QEMM386 that has the QuickBoot feature. I run the DOS tools and do a warmstart. Due to QuickBoot the computer does not enter the BIOS but directly the NT4 bootmenu. Now I change to NT4 bootup and it uses the already configured state.
Edit: Just seen the posts about GRUB, which can do the same job but more convenient.
Youtube Channel
Reply 18 of 28, by Caluser2000
Like the QuikBoot idea. I've had a copy of QEM386 for ever an never had a real excuse to try it.
Reply 19 of 28, by feipoa
You were able to run CPU-Z on Win95c and a 386DX? I got a blue screen with SXL2/Win95c and CPU-Z. Re: Need help to improve the support of 486/586/686 class CPUs in CPU-Z
