The 10$ "486"
First post, by DankEngihn
I regularly visit a local computer shop right behind my school, where I have gotten a lot of random computer stuff from over the past few years. A lot of times they don't have anything really interesting, and a TON of Pentium 4's and Core 2 machines, but occasionally I'll find something absolutely awesome. Well, it was one of those times.
Hidden away, amongst a pile of random junk, I stumbled across this absolute unit of a computer.
1.81 MiB
I was immediately attracted to it due to the 5.25" floppy drive, the big rocker-style power switch, and the MHz display on the front.
I pulled it out, and was told that I could take it, along with a few other machines if I wanted to. Hell yeah! 😀 😀 😀
So after getting it home, I took a look at it to see if I could figure out what was inside.
I looked up the writing on top of the case, and found that it had come from North Park Secondary School.
1.22 MiB
1.25 MiB
I then saw this sticker; detailing the hardware inside. Or so I thought.
1.34 MiB
Honestly the only thing left to do at this point was to fire it up, and see if it worked.
And it did! 😀
Also, I was greeted by this;
1.05 MiB
Wha..?? 😕 😕 😕 A Pentium? What kind of sorcery is this?
More coming later, on this machine and the others I picked up. 😎 😎
Reply 2 of 10, by DankEngihn
Thanks! I actually had the much smaller version of this case, and it housed a 1.6 GHz Pentium 4, 512 MB of RAM on some weird baby AT socket 478 motherboard.
Reply 3 of 10, by gdjacobs
430VX chipset has good odds for supporting Pentium MMX which effectively gives you a 486.
Reply 6 of 10, by DankEngihn
Okay, I finally had some time to get around to digging deeper into this computer. (School 😵 and personal stuff 😒 )
I opened the case, and was expecting to see a lot of dust. To my surprise, the inside was VERY clean. 😲 Of course there was the usual rat's nest of cables flying around inside the case.
1.71 MiB
I started to dive deeper into the machine, and find out what hardware was installed, and any potential upgrades that I might consider.
Taking out the cards from top to bottom revealed;
1.73 MiB
An out-of-place Dlink ethernet card. This was most likely an upgrade, as it has a date stamp of 1998.
1.2 MiB
A PCI ATI Mach 64. A 2 MB PCI video card that apparently also has a sound card on a compressed ISA bus. 😕
1.93 MiB
And lastly, a Sound Blaster Vibra 16C
Now, one of the reasons that I opened this thing up and removed the cards, was so I could replace the CMOS battery, which thankfully is a CR2032 coin cell, and not one of those horrid Dallas chips.
1.98 MiB
Reply 7 of 10, by chinny22
Good period correct 486, Our DX2/66 we got in 95 also came with a Mach64 and SB16.
Mach64 is bit slower for dos gaming and having PCI you have better options for relatively cheap, but it's not a terrible card.
Reply 8 of 10, by DankEngihn
It's been upgraded at some point in the past to a Pentium 166, and judging by the files on it's 5 GB hard drive, it was in use until mid-2018.
Reply 9 of 10, by Caluser2000
oeuvre wrote:
that case is dope brb finding $10 AT rigs somewhere...
People drop them off under my car port when I'm away mate.
