First post, by Crow
Hi, I've noticed that dgVoodoo defaults to 60Hz refresh rate by default and there doesn't seem to be a way to change it (I can't find it in the options). This is a problem since I have a 144Hz monitor and I would like to run games at that refresh rate. Right now I have enable "Enumerate refresh rates" option and specifically force resolution/refresh, which isn't very practical. Would it be possible to either add an option to just choose refresh rate globally or make it so that the default one dgVoodoo chooses is the one used by the desktop? I'm using 2.62.1.
Also it's not a problem of the games choosing to run at 60Hz, I tried it with multiple games and they run at 144Hz if dgVoodoo is not used.
Thanks in advance for any response.
