First post, by Nemo1985
Hello, I have some s3 cards with empty memory sockets, I tried to look for the chips on ebay but they are quite expensive, like €15 for a single chip, so I tried to look on aliexpress, and I found a stock of 10 pieces of chips for just €14, but i'm not sure if they can be compatible, here is the link: https://www.aliexpress.com/item/10pcs-lot-K6R … 2726268414.html
if they aren't good for the purpose, the only place where they can be find is it ebay?
Thank you in advance.
