First post, by justajeffy
I've got this HP Vectra VL that I'm trying to figure out how to open up. As far as I understand, step 1 is removing the front panel by unlocking the 2 clips on the bottom of the case. I can't seem to get them into the open position. I suspect that the clips might be installed incorrectly. Does anybody here have a similar machine they might be able to check if the clips look like mine?
Here's a view of the bottom of the case with the front facing to the left.
