First post, by buckethead
I've installed DosBOX, got it the directory etc as required.
I set up and installed the game Z, and it told me I needed to run the Batch file.
So I did, I ran Z.bat and it started to load, it gets to the part where a movie is about to play (I've installed the movie codecs) and it quits out.
So then, I read the FAQ and it said I needed to uncheck Read Only, so I did that, and it just goes back on again, and it won't go off.
Edit: I've just tried it again with some other additions, and now it say's I'm missing a file named "main.pac" 😒
