First post, by STX
The tops of these PSU capacitors are almost flat. Is this how they normally appear, or is the slight roundedness a sign of capacitor degradation?
111.04 KiB
TEAPO 680µF 200V
Thanks for weighing in. 😀
Reply 2 of 5, by luckybob
Those look like primary caps. (high voltage) And it's not uncommon to cover the metal with plastic for safety concerns. (think electrical shorts)
I have yet to personally see a primary side capacitor fail in anything i've re-capped. And I've only replaced them twice, and in both instances, I did so because I was re-capping the whole board anyway.
You can pull the plastic bit off. It's not glued on, but held by the outer plastic sheath. Personal experience tells me, there is a 99% chance those caps are just fine.
Reply 3 of 5, by PCBONEZ
What luckybob said.
Those are plastic discs.
Those caps are on the AC side and they rarely fail.
Reply 5 of 5, by gdjacobs
Yes. They live a simple, low stress lifestyle. They undoubtedly eat kale.
