First post, by JimLarimore
I have recently been going through and archiving all of my old diskettes. I was writing batch files to properly imgmount all of the disks to get them lined up for installation. But, I am running into a problem where some of these games with massive disk counts are problematic because I am exceeding the 128 character command limit in my batch files. I was hoping to using the caret symbol in my batch files to indicate continuation. But, DOSBox does not seem to understand this continuation symbol. I assume that there must be a solution to this problem as surely folks would be hitting this limit for other reasons. How do I exceed the command character limit? Or, can I add disks to the imgmount queue through multiple commands?
-Jim
Reply 1 of 6, by krcroft
Jim,
I see the dilemma: even if you're frugal with your floppy image filenames (1.img, 2.img, ... ) you are limited to mounting 16 floppies (that you can "flip" between with Ctrl + F4) before hitting the 128-character line limit.
In python ..
9 + (128 - len('imgmount a -t floppy') - 9 * len(' N.img')) / len(' NN.img') = 16
You could use letters (a.img, b.img, ... z.img) to squeeze in an additional 3 floppies.
If you drop the .img extension and name your images (1, 2, 3, ... ) you can mount 39 floppies. Maybe that's enough?
9 + (128 - len('imgmount a -t floppy') - 9 * len(' N')) / len(' NN') = 39
Reply 2 of 6, by JimLarimore
krcroft, thank you for the response. I did think of this short file name work-a-round. I guess I was hoping there was a more elegant solution because I want to maintain some level of reasonable naming conventions for these disks.
Reply 3 of 6, by krcroft
The DOSBox developers do support updates to accommodate proper installation of games.
If DOSBox's command line length prevents installation of a particular game (assuming reasonably named image files in 8.3 notation), then I think it would be fair to call the limitation a bug.
To present as examples, what are some games and their quantity of floppy disks that you're dealing with?
Reply 4 of 6, by dreamer_
Hmm, I did small test and can't hit 128 character limit (neither in command nor batch file) - at least not with `echo` …
JimLarimore, can you show us the command you have problem with? And how do you invoke your batch file?
| ← Ceci n'est pas une pipe
dosbox-staging
Reply 5 of 6, by JimLarimore
Apologies. This bug was reported by my dad who is archiving these disks. I just tried it out myself with police quest 4 (12 disks) and I wrote a command that had to be around 250 characters and it worked fine. I'm not sure what he ran into. But, if there is a character limit, it's a lot higher than we thought.
