First post, by Eirle
Hi guys, I discovered a few months that I have a Voodoo 3 3000 16Mb, I tested it, It looks like I have video scratches, possibly caused by some RAM chip, or the chip is bad solder or is dead.
I don't know if I send to repair or if I buy a broken Voodoo 3 3000 and replace the chips to see if it works.
I don't want to buy a 'new' one from eBay because mine is in perfect state. I just want to fix the RAM chip.
Here's exactly the same card, I don't have a cellphone to take a picture of it.
Are written in the chips EliteMT 5.5T 9943s M12L16161A H2692-HE., I don't know if this info makes any difference.
Powercolor EvilKing Pro 3 (Voodoo 3 3000 16Mb 166mHz)
http://www.vgamuseum.info/images/vlask/3dfx/v … 000pcolorfb.jpg
Why has God abandoned us?
Reply 1 of 9, by ifrit05
Most likely the RAM is on it's way out.
Solder/have someone solder new chips on or buy a new V3.
H2692-HE is a model number and 9943s is most likely just a date code (of manufacture, 43rd week of '99)
P3B-F v1.03 | VIA C3 Nehemiah 1GHz @ 1.33GHz| 4x128 PC133 | GeForce4 Ti 4200 | OPL3-SA3+DreamBlaster X2GS
Reply 2 of 9, by Eirle
ifrit05 wrote on 2019-12-29, 08:22:
I could buy a broken voodoo 3 3000 and try to replace the chips,there's no way i could buy a new one now,i have some taxes to pay.
Can i replace the dead chip by any RAM chip of 2Mb 166mhz with no problem or i should get the same chip from the card?
Reply 3 of 9, by PCBONEZ
You can probably find just RAM chips but you are only showing the last part of the model number.
Reply 4 of 9, by Eirle
PCBONEZ wrote on 2019-12-29, 19:09:
Sorry,i really haven't seen that.
The complete name of chip is EliteMT 5.5T 9943s M12L16161A H2692-HE.
Reply 5 of 9, by PCBONEZ
512K x 16Bit x 2Banks SDRAM 183MHz 3.3v 50-pin TSOP-II
http://pdf.eepw.com.cn/m20090909/c9671eef8722 … 1ec42424f15.pdf
Reply 6 of 9, by Eirle
PCBONEZ wrote on 2019-12-29, 19:59:
Thank you very much,i was trying to find it in the official ESTM website but didn't find the exact model.
Reply 7 of 9, by PCBONEZ
These are the same but faster at 200MHz
Reply 8 of 9, by Eirle
PCBONEZ wrote on 2019-12-29, 20:03:
Thanks again, the graphics core runs at 166mhz, the SDRAM will be limited to 166mhz too?
I could overclock it to 183mhz, but I have the fear of burning the card or something.
Reply 9 of 9, by PCBONEZ
It's not a problem.
M12L16161A-5TG will clock down to any slower speed common on Voodoo cards.
From page 7 in the PDF I provided.
48.28 KiB
It has the added advantage that if you ever want to overclock a voodoo card the RAM speed won't be a problem.
