First post, by buckeye
I know big decision here, but my retro setup is on a fold up table with a surface that makes the mouse
"twitchy". A trip to Walmart showed various brands steelseries, corair, etc. for least 12 bucks. Any
recommendations here that might be cheaper?
Reply 1 of 11, by aaronkatrini
Blank A4 paper?
Nothing cheaper than that! 😉
Reply 2 of 11, by pentiumspeed
Fine patterned surfaces will do anything fine. I'm using piece of cut cardboard from tissue box as mouse mat over my anti-static mat at work.
Great Northern aka Canada.
Reply 3 of 11, by Mister Xiado
I've only ever had tracking issues with pads that had grids printed on them.
I always use your typical cheap foam mouspads you can get from places like ArtsCow. I had a few with my insignia made about ten years ago, and they're still working fine with every type of mouse I use, though they periodically need some scrubbing.
Reply 4 of 11, by Unknown_K
Cooler Master mpa-mp720.
https://www.wootware.co.za/media/catalog/prod … 993-094_001.jpg
Large for people who like a lot of mouse movement, easy to clean, very precise surface, very rigid, you don't have to use the lighting.
Reply 5 of 11, by buckeye
Thanks all for the ideas. I'm using paper right now, never thought to use cardboard.
Reply 6 of 11, by Errius
An old hardback book works.
What's the problem here? The mouse can't handle surfaces that are too smooth?
Is this too much voodoo?
Reply 7 of 11, by pentiumspeed
What I mean is patterned, and texture either works well with one condition: matte surface. Since shiny surface even has patterns in it since LED reflects too much and blind the sensor.
Cheers,
Reply 8 of 11, by Errius
Right, surface too reflective is the problem. Makes sense.
Reply 9 of 11, by buckeye
Errius wrote on 2020-02-14, 21:46:
This is just one of those cheap fold-up tables, guess the texture on it is throwing it off.
Found a cheap plastic mouse pad at work that's doing the job.
Reply 10 of 11, by Ozzuneoj
Icemat!:)
Reply 11 of 11, by MAZter
Good for both mouse types
Reason: removed eBay link
