Reply 20 of 25, by darry
I think it is what is supposed to be a timpani but sounds like a crash .
Got the MIDI from here : https://midiarchive.co.uk/midi/Games/Duke%20Nukem%203D
Recorded from Windows 98SE Media Player using Sound Recorder (Tried it in GSPLAY after sending a GS reset and it sounded the same) .
EDIT : Does not sound balanced either with that dominating bassline .
Sorry about the clipping, the line in recording level (what the daughterboard output is routed to on Audiotrix 3D/XG) was set to minimum (I could not attenuate it more), so the clipping is likely occurring because the daughterboard is overdriving the line input . That is not the cause of the crappy sample, but the clipping certainly does not help .
