memory modules weirdness
First post, by truemaster
hello i have a problem with ram stick and i would like to know more before i buy a new compatible one
i have a 512mb memory stick dual sided that is compatible with an intel 815 board via apollo pro 133 (only 256 usable) but not compatible with via apollo pro 133a.
to be presice the via apollo pro 133a motherboard is a qdi advance10f rev2 i also have an infineon 128 mb stick one side that is compatible with all of my test mobos
here some photos of the modules and their specifications on cpuz
Reply 1 of 15, by computerguy08
truemaster wrote on 2020-04-30, 09:39:
Which one is it? You can't have i815 and Apollo Pro 133 on the same board simultaneously.
Reply 2 of 15, by dionb
Those are some dark photos. Can you give us the text on the black chips on the modules?
One difference is the CAS Latency. The Infineon module is CL2, the other module is CL3. If your BIOS timings are set for CL2, a CL3 DIMM may not work. How do you have the timings set in BIOS on the 694X board?
Reply 3 of 15, by truemaster
thanks for reply. i use now the qdi advance 10f (the apollo pro133a) the latency cas has 2 values for both modules the difference i see is the infineon on jedec #1 is 100mhz 2.0-2-2-5 the no name one jedec #1 125mhz 2.0-3-3-6 their jedec #2 is the same 133 3.0 3-3-6 i can see the numbers on black ics on the no name for now is 48lc32m8a2
my bios ram settings are the default ones
Reply 4 of 15, by dionb
truemaster wrote on 2020-04-30, 12:21:
Sure that's complete? That sounds like a Micron MT48lc32m8a2xx-xx, Those last "xx" numbers are the most relevant here, that's the cycle time.
Defaults are great if everything works fine, if not it's always worth double-checking as there can be bugs in defaults. In this case they look good - PC133 CL3 is 7.5ns, so 8/10ns with CAS 3 should be OK
So... why isn't it working. Good question. I'm trying to find a QDI memory QVL, but that's not so easy...
Edit: QDI doesn't seem to have published QVL lists :'(
Did find some BIOS files on archive.org - none specifically lists memory compatibility, but if you're not running version 4.6 it could be worth a try:
https://web.archive.org/web/20011202070430/ht … _advance10E.htm
Reply 5 of 15, by truemaster
i had just a previous bios revision 4.5 i will update it to 4.6. worst case senario i will try to find the exact same module i have total 128 now, another 128 will be enough. but i will make some test to see if the 512 one is really no go first. but is still weird on a slot 1 qdi advance (apollo pro 133) the 512 works and the settings are the same.
Reply 6 of 15, by truemaster
ok i test the no name with updated bios still no dice. but i have the serials of the ics
infineon HYB39S256160CT-7.5
no name 48lc32m8a2-75
Reply 7 of 15, by dionb
Weird... the Infineon DIMM is rated for CL2, but with 7.5ns it should only be able to do CL3... Still, Infineon is solid stuff and can frequently handle more than its official rating.
I'm afraid it looks like a compatibility issue between the motherboard and the DIMM. That's unusual as Via memory controllers tend to be slow, but very compatible. I'd say try and find a different DIMM - this board should support up to 1.5GB of PC133. With Win98Se going over 512MB is problematic though, so a single 512MB DIMM it does like would be optimal.
Reply 8 of 15, by truemaster
thanks for the advice. because its via i though that might be configuration issue. but you confirm my first though. i will buy an exact same brand with same timings as my infineon that will be ok for sure
Reply 9 of 15, by truemaster
a small update i have free time today so i mess with the bios configuration. at the line 5 in my photo dram clock if i change it from host clk to hclk-33 the 512 no name memory will work. what i dont know is if such selection has negative impact on performance. i(theories) f the only impact is the memory to work on asynchonous 100fsb its no big deal. but if the whole system is underclock then its no go for me
Reply 10 of 15, by computerguy08
truemaster wrote on 2020-05-01, 15:19:
If it doesn't mess with the FSB speed, you shouldn't see a big impact on performance. The memory will run at PC-100 specs.
What CPU are you using ?
Reply 11 of 15, by truemaster
pentium 3 800mhz eb 133fsb. i had instabilities crashes and when right clicking on desktop the comands messed up. so i revert the changes and put the 128mb infineon back. looks like i need to buy a new memory, and forget about this 512 module
Reply 12 of 15, by computerguy08
truemaster wrote on 2020-05-02, 08:30:
Get a pair of 2 x 256MB PC-133, it should be good enough for that machine.
Reply 13 of 15, by truemaster
can you recomend some modules for chipset 694X ? last thing i need is a set of uncopatible ones. although via is compatible with almost anything but i have some fear
Reply 14 of 15, by computerguy08
Don't take my words for granted, I always had luck with Infineon and Samsung memory sticks.
Reply 15 of 15, by truemaster
yup since ive got one working infineon. im gona take either 2x256 or 1x512 same brand
