First post, by sunaiac
- Oldbie
I'm trying to move my GA-7IXE system from its old school IDE drives to a SSD.
Bought a Sil3114 PCI card.
Card detects what I plug in it, I can reach the card's BIOS.
It hangs after detection.
So far, so good, nothing unexpected given its equipped with the raid bios.
My problem is, none of the solutions that should solve this are working (SIL3114 sata card, need ide firmware.)
- The JBOD solution : JBOd doesn't appear in the list of options, just raid(0/1/5/10), concat and spare.
- I can't flash the BIOS. My card is equipped with a iN28F010 bios which is undetected by the flash utility, and none of the "compatible" mode it gives me to try have worked so far.
So, the question :
- has anyone flashed a card with the same bios ?
- If yes, with which utility ?
- If no, do you know of any card equipped with the "correct" (AMD 29F010B, SST 39SF010 ...) bios under an easy to spot reference ? My card is quite generic, no idea who built it.
- Or maybe a better SATA PCI card alternative to propose for a WIN2000/WIN98SE system ?
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
