First post, by ratfink
I've just got a copy of Apache Longbow, and tried running on my Win98 machine.
Software version runs fine, but I want to try to 3dfx version. Machine has 2 Voodoo 2's running in SLI. I've installed the 3dfx-enabled version of Longbow, I can change the program settings [under Preferences] but when I try to run Arcade [say] the computer locks with a black screen [can just make out the 3dfx logo].
Any ideas? Do I need to not run Win98 but Win95? Could it be a DirectX problem - I have 8.1 installed whereas the game comes with a version much older? I have tried turning off SLI and limiting memory for glide apps to 2mb. No joy.
The Voodoo drivers are the Creative originals, which work on everything else [including AvP, which is cr@p on my pachine if I use FastVoodoo2-4-6 drivers].
Reply 1 of 4, by Carrera
Use environment variables to fake it into a Voodoo1
Reply 2 of 4, by ratfink
Sounds interesting...
Do you mean edit the driver files?
Is that what this is about:
http://www.mdgx.com/3dfx.htm
Any guidance on how to set a V2 to act like a V1?
Reply 3 of 4, by Davros
i beleive you put the following in autoexec.bat
set SST_GRXCLK=50
set SST_FT_CLK_DEL=0x4
set SST_TF0_CLK_DEL=0x6
set SST_TF1_CLK_DEL=0x6
set SST_VIN_CLKDEL=0x1
set SST_VOUT_CLKDEL=0x0
set SST_TMUMEM_SIZE=2
Reply 4 of 4, by Carrera
BINGO!
