First post, by Intel486dx33
It has an AMD 386sx-33 CPU.
386sx SARC
Rev 1.2C
I need a manual.
386sx SARC
Rev 1.2C
I need a manual.
Looks like a pcchips m396 with a made in America logo
Could be a PCchips, also could be an ECS board. Pull the logo off and see what chip is under OR if it boots post the bios string.
https://stason.org/TULARC/pc/motherboards/U/U … -486-C6332.html
Btw why do you need a manual when all jumpers are labeled on the board?
P/S: I would cut off that dreadful NiCD battery asap.
Slow down your CPU with CPUSPD for DOS retro gaming.
Gotta love the Made in Taiwan silkscreen along with the Made in U.S.A. sticker .
kalohimal wrote on 2020-06-13, 03:41:https://stason.org/TULARC/pc/motherboards/U/U … -486-C6332.html
Probably the same one .
MORSE TECHNOLOGIES, INC.
M4 386SX
darry wrote on 2020-06-13, 05:20:Probably the same one . […]
M4 386SX
Thanks, I think that’s it.
I already replaced the battery with a coin type.
Got to it just in time as it started to leak and was eating away at the traces.
Intel486dx33 wrote on 2020-06-13, 05:35:Thanks, I think that’s it. I already replaced the battery with a coin type. Got to it just in time as it started to leak and was […]
M4 386SX
Great.
Hope you put in a diode too in order to prevent the non rechargeable coin cell from getting recharged .
darry wrote on 2020-06-13, 05:20:Probably the same one . MORSE TECHNOLOGIES, INC. M4 386SX http://www.uncreativelabs.de/th99/m/M-O/32195.htm […]
M4 386SX
Yeah same. I use TULARC quite a lot for finding jumpers info for old boards when the manual is no longer available. The trouble is must slowly eyeball thru hundreds of pictures 😀
I don’t understand how to configure jumper 4
Intel486dx33 wrote on 2020-06-13, 08:07:I don’t understand how to configure jumper 4
You don't need to, since you don't have an FPU. Unless you added one, in which case you need to tell us exactly which one.
